Depending on your camera, the battery may be able to be charged on the camera or by using a separate battery charger. Refer to the section below that relates to the charging method you are using.
Charging while the battery is attached to the camera:
- Make sure the battery is firmly attached and the AC adapter is securely connected.
- If your camera can charge the battery with a USB connection, use the built-in USB cable to connect it to the computer. If you use a USB charger instead of the computer, check the compatibility of the USB charger.
- Turn off the camera. The battery is does not charge if the camera is turned on.
Charging using the battery charger:
- If the CHARGE lamp does not light or blinks when charging, the terminals may be dirty. Wipe the dust away with a dry cloth and charge the battery again.
- Make sure the metal contacts on the battery are free of corrosion.
