Not knowing how much you use the camera makes this a harder question to answer. Make sure the battery is fitted correctly but it might be a worn out battery. Using it a lot will eventually wear the battery out and only using it occasionally can affect the battery as it isn't charged.
Are you charging the battery while it is still in the camera? A separate charger is more effective. It might be worth investing in a charger if you don't have one and/or another battery.
Duracell supply both at sensible prices. Nikon CoolPix P530 Battery Charger
Please unplug the battery (remember to disconnect the charger),
then, hold on the power button for a minute,
after that, connect the charger, and try to power on the laptop.
If it didn't work, you need to visit the technician
If it worked, disconnect the charger and connect the battery
If it worked, things are going well.
If not, the battery have problem.
Hi, Since you have already tried with new charger the problem is on the phone charging socket.. I believe a soldering action is required on that area..you must visit a repair shop... Sorry about it.. Hope this helps! Take care and please Remember to rate / vote us to continue for Helping out the Community :) Thanks
This can be a number of things:
1 Remove your battery
2 Plug in the charger try turning it on
3 If it does you have a bad battery
4 Charge your psp through a USB cable(This may not work becuase I turned the setting for that on mine and it Didn't)
5 Let it your PSP full charge
6 If this works, chances are you have a bad charger.
You can get a generic 5volt charger anywhere for around $10 or so
Thank you for your time, Good luck and I hope this works
there i no need troubling yourself further, the problem with your phone is the charging port, the charging port of your phone is bad that is why, your phone battery cannot hold charge.
Change the charging port of your phone and your phone will charge and hold charge.
this is about average for on full time! Don;t confuse 'Standby Time" with actual usage time in continuous usage. Earlier models only gave 2 hrs!
I made a mod to be able to fit an Opti-Sola charger ( quite small) That uses solar power to recharge or extend running time. There are also battery units fror Palm Zires that can be modified tro fit this unit to get extended time in the field If you want more details of these items get back to me. [email protected]
If you have guides allowing to fit them there should be no problem. There is only one type of 8mm guide seals for the whole 750s range.
I think the original guides of early models didn’t have the possibility to fit them as they didn’t have a smaller diameter in that area. At those times many motocycles didn’t have them at all and it worked quite well I personally wouldn’t change the guides just for that. Aftermarket guides are only of the type that allows to fit the seals. ,,,
