Please check designated card for your camera in owner manual.
If it is OK, then try another good memory card ( with same type) and have your camera re-try.
If nothing change, problem is in your camera . It could be memory card ports/terminals, or its interface with PCB.
The manual specifies SD cards up to 1GB. Cards bigger than 2GB are actually SDHC (SD High Capacity) cards and will not work in SD devices. 2GB cards may work; try at your risk.
Unfortunately, the Pentax K100D is not SDHC
compatible, which means that the camera can be equipped with a maximum
memory capacity of 2GB.
It is also advisable to choose a fast
version of the Secure Digital memory card, such as Ultra II or Extreme
III by SanDisk. I would recommend using a memory card of at least
512MB, or even 1GB if you can.
The E10 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
