From memory, the breather is in the top of the tank, you would need to remove the tank to access it.
Guide bar and chain off.
Top cover off.
Two screws and air filter off
Remove two 10mm nuts and filter back plate off
Remove throttle rod
Remove two 7mm headed screws securing carb
Remove two cross head screws from carb bracket
take carb off, remove fuel hose
Remove 4 screws securing starter, note 2 m5 and 2 self tapping, must go back in the same position on re build.
Remove chain catcher screw, and top l/h screw, these 2 are into the anti vib rubbers chain side.
The tank should now come away with top handle still connected.
Breather is in the top of the tank, it is a small white plug, some also had a duck bill valve.
SOURCE: Fuel Leak
Hi
Yes.You dop not need to replace the entire fuel assembly only the breather.
best regards savumihai71
SOURCE: Poulan 14" chainsaw, fuel coming out of fuel cap vent
The fuel cap has a rubber check valve in the top. This check valve allows air to enter the tank so fuel can flow. Much like the vent on your gas can. Sounds like the check valve in the cap is stiffening and not flexing. Best bet is to buy a new cap. Most caps like that sell for less than $3.
SOURCE: No fuel getting from fuel tank to fuel pump
It has a screen filter inside the tank that may have gummed up.If you drain the gas and look inside the tank,You will be able to see it.
SOURCE: 2008 street glide gas cap
Yes it is a vented cap which is stuck in the closed position. Get a new cap and you will solve your problem
SOURCE: Nissan Altima cranks, but won't start. Open the
no it has a closed system so no smell of petrol so their is something wrong with the suction pump and the pipes that come from teh engine compartment
Testimonial: "Thanks for being so quick!"
Thanks for taking the time. Just need to clear work bench!
