First, update your hardware drivers via built in applications or the Toshiba website. Try the Windows Troubleshooter for Networking... it works much better than before. If you're out of warranty, your only option may be to purchase a USB wireless LAN adapter. Buy one from Amazon so you can return it if the problem isn't fixed.
SOURCE: my Toshiba SP6000 cannot enable
Hi Alirahmani26,
From what I've gathered here, you're trying to use a wireless card on your laptop to connect to the Internet through your desktop computer. Are you using a wireless router somewhere in there? Or are you wanting to connect to the Internet FROM your laptop THROUGH your desktop computer? If the latter, are you planning to connect the laptop with a Cat-5 cable or with the wireless connection?
Ben
SOURCE: toshiba satellite a205-S5800 lost internet connectivity
go to device manager, see if there is a driver for the wireless adaptor...try disabling and enabling it...see if that works. if that doesnt, see if u got the wireless connection still wrking....bt sometimes kills the wireless connection, changing the channel helps in this case....
tell me wats goin on
SOURCE: can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for
you to connect it that way. DVI/HDMI is a digital signal and if it's a
digital-based display tech TV, then you're better off using that. Also
if the TV does resolution above 1360x768 (i.e. if it does 1080p) you
can get higher resolution by going via DVI/HDMI...
SOURCE: My Toshiba Satellite's wireless won't work. It
Try the properties of your Network controller. And go to your Internet Protocol Version 4 and 6 properties. Sometimes you have to change from Auto Obtain to manual and back again to get the IP addresses to correct themselves. Hope this helps.
SOURCE: my toshiba satellite laptop won't connect
As a general test, see if you can ping the "router's configuration URL IP address". To do that go to a command prompt(DOS Prompt) and type in ping and the routers IP. If you get replies you are OK conencting as far as the router. Next try PINGing to www.yahoo.com or www.google.com. If you get replies you are OK conencting as far as the Internet. If not try sending a ping to their IP(the numbered) address. If you get replies you are OK conencting as far as the Internet, but you have a DNS issue. Big Pond can help you with that.
Testimonial: "Thanks! I have been able to establish I have a DNS issue."
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? For example the system you are using win10 , 7 8 or linux.
