Angle Hello I need to know if the Bushnell Pinseeker 1500 with slope model are able to measure angles more than 20? although it doesn´t calculate the compensate distance.Many thanks in advance , please if you could send the answer at [email protected] i will greet a lot.
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
Hold down the "MODE" button until the "M" starts to flash......touch the mode button again till the "Y" flashes........then touch the "FIRE" button on top.....(square button) Then it will be set to read in yards....not meters.
E6 means the unit has cpu or program failure....The only thing that bushnell can do is replace your unit with a newer one Its over 10 years old..... They won't have any parts or able to reprogram it.(they just do keep parts that long) They will offer you a model 20-1916 ($151.00 bill) (you can it see it @ bushnell .com.) The better model is........if you play golf is the Medelist(20-1354) or the Tour V2(20-1930).....The top of the line is the Pinseeker 1600(20-5105 without the slope function) or the Pinseeker 1600(20-5106 with the slope function).......If you hunt I would go with the model (20-1932 with the ARC fuction..... This is the real deal....call them
bushnell.com>north america>english>golf>laser rangefinders>Pro 1600 Tournament Edition> now look at the bottom of the page and you will see MANUAL. The 1600 and 1500 work exactly the same way. The only difference is the outer case and battery door. Trust me....
The rangefinder is out of alignment. Vibration, dropping these units make small mirrors inside move slightly. Over time the receiver cannot see what the transmitter puts out. Bushnell can fix, 4-5 weeks w/o unit.
Bye the hunter's edition. It has the same features but the slope is called arc and the pinseeker is a target. The target works the same as the pin, except it was desighned for small game but it is the same unit. The slope is called arc and is used for bow hunting and ammo drop in inches per yard.
I'm having the same problem, but the normal yardage seems to be working fine. I tried calling Bushnell, they said I would have to send it in to them and they would fix it. I'm thinking it's got to be something easy to fix.
Mine was doing this too, although I can't officially confirm it from anyone in "the know". I guessed this mean't "low on battery", I replaced the battery and the flashing lob went away.
