I have L295 fax machine. It sends fax but does not recieve. That is, it does not print. It says check printer ##322
Error message check printer ##322 displays due to faulty Fuser Assembly. You can send Fax and receive but cant print due to faulty fuser assembly. Replace fuser assembly to fix your printing problem and error message.
Change your faulty fuser assembly.
Fuser Assembly Replacement Procedure:
Remove upper cover(4screw), than remove axis with few small rollers, than remove from right side toner crg holder ( black plastic peace on right machine metal side ), unscrew 2 screw on black cover, remove it, unscrew two screws on metal cover ( beneath black plastic cover that you removed )
The Fixing unit of the fax is blown.Replace the fixing unit.
