Mitsubishi WD-52631 52" Projection HDTV Logo
Posted on Aug 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
For some reason when I turn my tv on it's shuts off within a minute. i hear it start up and then shortly it powers down. There is no picture or warning. I do hear the volume of the channel im on. What could this be?
Anonymous
Level 3:
  • Master 556 Answers
  • Posted on Aug 14, 2009
Anonymous
Master
Level 3:
Answers
556
Questions
0
Helped
154246
Points
1096
Probably your lamp has gone out, does the lamp light light?
Mitsu 73732 dlp.I have no picture. have sound for about one to two minutes. Then it shuts down and red light comes on. has code 61
Audio output IC overheats. There are many reasons for this fault. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Mitsubishi "wd73642 I'm watching tv and then it shuts off and the status green light blinks green fast and the light goes off do i need a new dlp lamb
I have a Mitsubishi WD73642 model which I'm having a problem with it turning off. When power is turned on the status light flashes green and appears to be powering up. Then u hear sound. Picture comes on light turns sold green then within a minute the El TV will just turn off no other dianososis lights. TV is not located too close to the Wall. Any ideas why?
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
When i turn on the tv, it takes maybe a minute or two to turn it on.. red light flashes as it try to turn on what is wrong with the TV
The reason your television takes a while to come on and have a red light flashing before it comes on is because it is about to develop a problem and it is most likely a power problem.
If your television does not get properly shut down and power goes off on it without the proper procedures, it would start to flash the red light which is to sound a warning that your television would become faulty within a short period of time.
So ensure you go through the normal procedure in turning off your television.
Take care
2answers
Just got a 46hm95 toshiba for free cause the screen wont show anything. i can hear the fan come on. i am very mechanicly and electricaly inclined and have all things needed to test equipment short of an...
hello When the TV has been powered on long enough for the lamp unit to get hot, it may take several minutes for
the picture to appear on-screen. See "IMPORTANT NOTICE ABOUT HOT LAMP R
When the TV has been powered on long enough for the lamp unit to get hot, it may take several minutes for the picture to appear on-screen
in the following situations:
• When the Quick Restart™ feature is set to OFF and you turn the TV off and then on again within a few minutes.
• If the TV is on when a short-term power failure, power surge, or other similar power failure occurs, such that the TV loses and regains
power within a few minutes.
This is a property of DLP TV lamp technology and is NOT a sign of malfunction.
If this occurs, the green LED on the TV front panel will blink (and the red LED will be lit solid) until the TV is finished restarting the lamp
and the normal picture appears. If BOTH green and red LEDs are blinking at a one-second rate, you will need to turn the TV off and then
on again to restart the lamp.
ESTART" on page 8. if this no good check the lamp in side to see if it's not burn't out good luck
regards
shaun
1helpful
When turning on the TV, I hear a banging/grinding sound.
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?CLICK=52978
Please keep us posted.
No picture or audio.power light blink on once and turns off
The real deal here is the protection circuit has activated. This is caused whenever an excessive amount of current is being drawn from the main power supply. Upon detection of same, it immediately takes over the power management of the set and shuts it down. The clicking sound you hear is the ON relay turning on the set, but immediately the power mangement system shuts it OFF. You should hear two clicks, but they may be so close together that it sounds like one click.
This set is getting rather ancient and I would not recommend you spend much money on it for this reason: It is highly likely that once the set if repaired that another failure would occur. This is because of the law of averages; the first failure is often followed by another failure from anywhere within the set.
Power light comes on,clicks before picture comes on then shuts of
Yes, it is either that or the "Startup Circuit" is faulty usually it is the associated relay. Thats the clicking sound you hear. When you turn on the TV, the relay is activated along with a timing transistor, the Relay has to make contact within a certain time frame. If the contact is not made during that time frame, the TV shuts down. This is a safety feature in all TV's. If you can get a schematic it will show you where the relay is or, after you unplug the TV and wait 15 minutes, you can take a look inside at the main circuit board, sometimes they mark the area with either "START UP" or "SHUT DOWN" and there you should see a relay.
But a new one usually has to be soldered in.
Toshiba CF3566A Tac 9190
the cuestion is if every time it shut down you have the hot shorted,or not. have measure the flyback/yoke/Hot working current? it must be under 0.6Amp ,if is greater something is wrong and cause overheating.Normally I touch with my fingers to "measure" the temperature. and what about the Micro?.there´s one pin that control power on/off ,is it good-solid data or is crazy . micro gets hot, have a correct 5Volt on its VDD pin. lot of cuestion that I hope helps you!!!
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
