My amp will not produce any bass frequency. I check the preamps and i noticed that first two tubes were not lit( going from left to right the first two tubes not lit) I tapped that tubes with a chop stick to see any ringings, but nothing. Will replacing th tubes fix the problem or better yet take it to the a shop.
HI,
Switch your amp on and leave it in the stand-by mode, you see tubes glowing.
Than you can pull another tube (same type) out of the amplifier and put it in those sockets. If they are also not glowing, there must be a wiring problem.
It very strange that there are two tubes not glowing.
Give it a try, you can do it yourself.
Reagrds Gerard
