I was playing with the remote and turned off the "Auto Play" functions for the VCR and DVD and now I can't get anything to display on the t.v. screen. I hit the "Setup" button but it won't display...actually there are no screens that display on the t.v. monitor. I can hit "Play" and "Eject" and they work...I can see "Play" on the machine's display and can see that other functions are working because I notice them on machine's display screen, but when I hit "Play" there is no image on the t.v. monitor for either the VCR or DVD.
There should be a tv vcr button on the remote control. What you done was you accidently shut off the VCR function. If you hit that button again the tv vcr button it will come back on.
Testimonial: "Thanks! I forgot to mention that the model no. is DV2150...will your solution work for this model?"
Same problems with my unit. But, try this... I think it worked. First, you can not get to the setup screen for the unit with a DVD in the player. So, remove the DVD first: Unplug the unit, wait a few seconds, plug it back in. Then hit the DVD open button and remove DVD in player.
I think the issue with not reading certain DVDs is a problem with the "parental control" on the unit. Without setting parental control there were a few DVDs I could not play and sometimes (not always) I was asked about parental control before a movie would play. At the Sony Blue DVD screen, select Setup on the remote control. Select DVD setup and get to Parental control. Set a password. This will then take you to a "rating" screen. By setting the rating very high (I set mine for #8) any movie should play without needing the password. With no password set, you can not change the "rating" and hence mine was set at #1 (kids). It seems to have worked for now anyway. Good luck.
