Garden Logo
Posted on Aug 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i change the chain on my mac 3200
Dennis Sharp
Level 2:
  • Expert 154 Answers
  • Posted on Aug 11, 2009
Dennis Sharp
Expert
Level 2:
Answers
154
Questions
0
Helped
57287
Points
246
Remove the 2 nuts holding the cover on, then back off the set screw remove and repl chain, install cover snug,then adjust chain tension ,tighten nuts
5 Related Answers
Anonymous
  • 2176 Answers
  • Posted on Jul 01, 2009
SOURCE: How do I adjust to chain tension on my Mac 3200?
When I service one I clean all the debris out of the covers and the rail in the bar. Then reinstall all parts with the chain a little loose. Using a pair of gloves have the hex nut on the cover loose enough so you can raise the tip of the bar, while doing this use your screwdriver to adjust the screw so that when you lift up on the chain just the bottom of the teeth are about exposed. (drive section) still holding on the bar snug the hex nut and again lift the chain, after doing this pull the chain bu hand (with gloves on) to make sure it rolls freely and I always recheck a third time and then tighten the nut fully and go cut some wood
Anonymous
  • 2220 Answers
  • Posted on Sep 26, 2009
SOURCE: How do I remove the sprocket and clutch on the Mac
Use this as a guide:
R² Drive Link Outboard Clutch
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check at the IPL for your saw to see if any special tools are needed.
  2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. It is probably a left handed thread (tighten it to loosen it).
    Let us know how it worked for you. GL
    Lou
Anonymous
  • 2220 Answers
  • Posted on Oct 22, 2009
SOURCE: oiler does not work on Mac 3200
I cannot find any 3200 series IPLs. Individual models can be found here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
If this is a Chinese Mac (MTD) they are very difficult to work on. Most saw shops will not repair one. GL
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
Lou
Anonymous
  • 2220 Answers
  • Posted on Oct 24, 2009
SOURCE: I NEED A ASSEMBLY DIAGRAM FOR A 3200 SERIES MAC
McCulloch IPLs
This isn't very detailed I'd use the individual drawing.
https://www.dixiesales.com/ipl/327/Chainsaws_32cc-35cc.pdfIf this is a Chinese Mac (MTD) they are very difficult to work on. Most saw shops will not repair one. GL
Lou
Anonymous
  • 1627 Answers
  • Posted on May 11, 2010
SOURCE: fuel mixture
Mix the oil to gas at a ratio of 50:1.The oil bottle will tell you how much oil and gas you need to get to that mixture.
Testimonial: "Thank you for your help. Leon"
How do you get to the oil filter and how do you clean it and change it.
How to clean the chainsaw's air filter - YouTube
? 3:11
https://www.youtube.com/watch?v=wozSufvtbfE
May 30, 2012 - Uploaded by iScaper1
Tips for removing and cleaning the air filter on a Stihl MS250chainsaw. ... A very dirty air cleaner, a little maintenance can help them live longer ... Poulan Chainsaw Review- Should youbuy one? ... chainsawbars.co.uk - cleaning the air filter andchanging spark plug ... Get video URL at current time.
Mac 3200 chainsaw oil tank repair - YouTube
? 3:21
https://www.youtube.com/watch?v=XXlm-o8sD6A
Jul 17, 2012 - Uploaded by conan6868
Repairing oil tank. ... Could You Fix This Mini Mac Chain Saw! ...The chainsaw guy takes the McCulloch Mini Mac ChainsawChallenge 9 23.
Mucculloch 3516 chain saw assembly - YouTube? 49:25https://www.youtube.com/watch?v=Xm4YL3pDG8cJan 20, 2014 - Uploaded by Dragracer64In this video I take a box of dirty chain saw parts that has been sitting in my attic for about 12 ... Is there supposed to be a filteron the line in the chain oil tank? .... How to replace MCCULLOCH chainsaw MAC 3516 fuel line.How to replace MCCULLOCH chainsaw MAC 3516 fuel line ...? 1:32https://www.youtube.com/watch?v=GMjXYKza-NYJan 13, 2013 - Uploaded by Lambda ITCMCCULLOCH chain saw MAC 3516 chainsaw fuel line replacement. Three fuel lines. 1) First line in the tank ...
How many drive links does the MAC 3200 14" chain
A good saw shop will be able to set you up with the correct chain.
Apr 09, 2013 • Garden
1helpful
My chain can off my mac 3200
There should be two nuts on the main body of the saw just near where the chain bar enters the main body. Loosen them, slide the bar into the body, adjust the chain as needed, pull the bar out a bit to tighten the chain onto the bar, then tighten the nuts. You are good to go. Good luck. Please rate me.
I need to know which oil type goes into the oil chamber for the chain on a mac 3200 gas chainsaw, not the mixture...thanks
There really is no exact type of oil that goes into the chain and bar oiler. Each manufacturer usually makes their own, but any chain and bar oil will work. It is a thicker type of oil unlike a motor oil. Just ensure that the bottle says "bar and chain" oil
Want to change a maxtor 3200 from windows format to apple mac
When you plug the drive, once mounted on the mac, go to applications>utilities>disk utilities then select the drive and choose partition. If you want the drive to be bootable you should then choose Mac OS Extended (journaled).
Cheers
Want to purchase bolt to adjust the chain on my mac 3200 Chainsaw
You local Mower Shop should be able to help you, he can order one for you
Need to locate chain & bar oiler adjustment screw for mac 3200 chain saw
Look to the lower left side of the bar (as you hold the saw normally)--there should be a screw head in the engine case there. Check the adjustment by holding the bar tip at speed near a piece of cardboard for a couple of moments--it should throw off a thin line of oil. Hope this helps!
1helpful
I am looking for a manual for a McCulloch 3200 chain saw.
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
http://www.arboristsite.com/showthread.php?t=72322
I saw 3 requests for 3200 no replies. Tried Mac 3200 and McCulloch 3200, no hits. Post it. Good Luck. HTH
Lou
McCulloch International was fruitless too, Call them, please then post to ArboristSite is my best advice.
2helpful
I NEED A ASSEMBLY DIAGRAM FOR A 3200 SERIES MAC CHAIN SAW.
McCulloch IPLs
Lou
3helpful
Oiler does not work on Mac 3200 chain saw
McCulloch IPLs
Oil System Plugged.
Lou
Top Garden Experts
Jay Finke
Jay Finke
john h
