Yard Machines Red Edger Logo
Posted on Aug 11, 2009
Yard Machine tractor drive deck belt failure
I have a 48'' MTD Yard Machine (#13AN601H729) lawn tractor that keeps having deck belt failure. I have not noticed any problems with the pulleys. Is this a common problem with this model or is it just mine?
Tom Radloff
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 16, 2011
Tom Radloff
Contributor
Level 1:
New Friend:
Answers
Questions
7
Helped
1487
Points
I need a diagram of tensioner springs on yard machine deck 1998 42inch
Anonymous
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Oct 02, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
0
Helped
9488
Points
34
Diagram for belts on a 48 cut yard machine
http://www.ereplacementparts.com/mtd-13aq617h118-2003-lawn-tractor-parts-c-20039_20060_133253_24406.html MTD 13AQ617H118 2003 Lawn Tractor Parts
1helpful
Belt diagram for 46" mtd yard machine riding mower
You can find the belt diagram for the MTD Yard Machine mower in the MTD Owner Manual. The diagram is on page 21.
How to put on2004 yard machine deck belt
in most cases you have to take the deck competely off the tractor to replace either deck or drive belts on the yard machines. unfortunitly that is the way they were built. I am a lawn mower sales and service manager
Jul 28, 2012 • Mtd Garden
1helpful
What is the correct belt size for yard machine lawn tractor 18 hp. with a 42" deck model # 136aq670g62?
Take your make and model number (located under seat) to your local lawn mower repair parts shop and they should be able to get you the appropriate belt.
If helpful, please rate.
Need a deck belt diagram for MTD 13AL452F120525197-115
I also need a deck belt diagram because a manual didn't come with my 746 SRL yard machine
3helpful
Yard man mtd 20hp 46"cut hydrostatic drive lawn tractor,model"13AU69H401 deck belt need diagram to put it back on?
go to the online web site for the yardman this will give you the guide on how to replace the belt.
5helpful
4answers
MTD Lawn Tractor: Constantly shredding deck belt...
I have the exact same model MTD tractor with same problem. It began when the bolt that extends through the idler arm assembly broke and subsequently damaged the pulley. Upon examination of the broken bolt, I found that the threaded end that extends below the deck is significantly smaller that the rest of the bolt. I got a larger bolt with the same size threads, bored out the hole through the deck and it made the whole idler assembly much stronger. the deck still has some vibration and some unusual belt harmonics, but it appears to be working. Compared to most other tractors of this size, this deck is very complicated.
Jun 05, 2009 • Mtd Garden
Top Yard Machines Garden Experts
john h
Jay Finke
Jay Finke
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
