Re: 1964 johnson 9.5 hp outboard runs but no reverse. Any...
Pull the stablizer pins and row back to shore, lol j/k. Did you check the linkage to make sure it was working properly, look on the motor itself not on the feel of it..
Pull the stablizer pins and row back to shore, lol j/k. Did you check the linkage to make sure it was working properly, look on the motor itself not on the feel of it..Pull the stablizer pins and row back to shore, lol j/k. Did you check the linkage to make sure it was working properly, look on the motor itself not on the feel of it..
You can't post conmments that contain an email address.
What is the mix ratio for a Johnson outboard motor?
Any Johnson outboard motor built since 1964 requires a 50/1 fuel ratio. Motors built prior to that date require a 32/1 ratio, with the exception of a few fishing motors built prior to 1955 that use a 16/1 ratio.
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
50 to 1 all ways go for the higher as the oil is lube and a hot outboard needs it if you are wrong it will still run hard to push a boat home but in this case 50 to 1 is the one be safe on the water
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Johnson and Evinrude carbureted 2-stroke outboards since 1964 require a 50:1 fuel to oil mixture (2%) on engines without an automatic oiling system - 6 gallons of gas to 1 pint of outboard oil.
sound like the shift fork, or fwd gear is damaged in the lower unit.....special tools are required for this repair .....if you got them cool, if not seek a shop for further assistance.......hope this helped...GL
