Question about Salter Health & Beauty
What does Error2 mean on my Salter digital kitchen scale? There is no model on the scale but it measures in Kg and LB Max 3kg X 1g:7lb X 1/8 oz.
6ya staff
SOURCE:
Anonymous
  • 3 Answers
SOURCE: conair ww17 scale measures in kg not lb.
There is a switch on the bottom of the scale on mine to use either lb. or kg.
Posted on Dec 20, 2008
Anonymous
  • 10 Answers
SOURCE: my salter 1004SSDR kitchen scale won't show any
Your salter scale has a 15 year warranty. I would call the customer service number 1-866-843-3905 and ask them why it won't zero to weigh anything. They may replace your product.
Posted on Sep 10, 2009
Anonymous
SOURCE: E appearing on display of Salter kitchen scale
i have the same problem- did you manage to fix it??
Posted on Dec 29, 2009
LaidlawUk
SOURCE: Kitchen scale, Salter, model 2006: change batteries
The 1 part just slides off.
Posted on Jun 28, 2010
rigadon
SOURCE: I have the Salter Scales
I just had a play with mine as I wanted to change the weight mode too.
The solution is this:
While the machine is OFF, press and hold the button for about 5-10 seconds.
The display will go from 8888 to show the weight measurement (lb oz) at the top of the display.
Press the button to select the weight you want.
You should be able to continue with your baking :o)
Hope this helps
Posted on Mar 15, 2011
Conversion from kg to pounds or ounces
1 kg = 2.20462 lb
[http://www.metric-conversions.org/weight/kilograms-to-pounds.htm]
1 lb = 16 oz
Apr 15, 2015 | Home
Am trying to add clarification to an earlier question. The scale I am asking about is a wall mount kitchen scale: the make is Salter, the model 1601. It worked fine for several years until I changed t
Is it possible you put the batteries in the wrong way? Sometimes a device will still have power in that situation, even though it won't work as expected. Try a new set of batteries, but clean the contacts in the battery compartment first, and double-check the battery orientation.
Dec 20, 2014 | Salter 2001 electronic kitchen scale
1 lb 60z what is mean.pls answer me
What's the question?
Since one pound is sixteen ounces, 1 lb 60 oz is 4 lb 12 oz.
Aug 17, 2014 | Cars & Trucks
I have the Salter Scales model 2040, it is currently sent to oz, do you know how to change to grams as there is only 1 button. thanks
Hope this helps
Oct 09, 2010 | Salter 2001 electronic kitchen scale
Setting the clock on salter scale model 5007
Hold down the g-oz key and the off key at the same time for about 5 sec's
The hour digit will flash
press the ml-floz key to move the hours.
then press the g-oz key again to move to the minutes.
press the ml-floz key again to set the minutes.
press the g-oz key and it moves to setting the cloak to 12h or 24h option.press the g-oz key to set the time.
And your done.
Oct 06, 2009 | Salter Bakers Dream Aquatronic Kitchen...
My salter 1004SSDR kitchen scale won't show any real weight - just stuck on '5000' which is the max weight in grams, won't switch off, crazy
Sep 09, 2009 | Salter 9007 Glass Lithium Digital Scale
Mar 31, 2009 | Salter 2001 electronic kitchen scale
Conair ww17 scale measures in kg not lb.
Dec 11, 2008 | Conair Large Digital Display Memory...
Health & Beauty Logo
35 people viewed this question
Top Salter Health & Beauty Experts
Simon Ruddy
Simon Ruddy
Level 1 Expert
WordGoddess
Level 1 Expert
Terry
Terry
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
