Question about Garden
Rubber antivib mounts on a Castor 330 are gas and oil soaked to the point they are falling apart can these be replaced easly or will i have to order them and wait
  • 154 Answers
Home depot has different rubber bushings they sell, to replace them,
Posted on Aug 23, 2009
Testimonial: "THANKS FOR YOUR HELP"
6ya staff
SOURCE:
How do i know which motor mount needs replacement
With car in drive/reverse and foot hard on brake if the engine moves when gas pedal is depressed and quickly released in both D&R, then that mount/mounts is defective...
Engine mount should be replaced if:
1) The hard rubber surface is covered with heat check cracks.
2) The rubber is separated from the metal plate of the engine mount.
3) The rubber is split through the center of the engine mount
The transmission case will crack or break if either engine mounts or transmission rear mount is broken...Here is a GM Service bulletin addressing the issue:
#02-07-30-024B
The transmission mount (see drawing) test:
>Raise and support the vehicle
>Raise the transmission/transaxle in order to remove the weight from the transmission/transaxle mount and create slight tension in the rubber.
Replace trans. mount if anyone of the three conditions listed above exist
...saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Jan 02, 2015 | 2004 Chevrolet Impala
How to treat hairloss
Hair loss is the major problem for many people specially men. Many young men are using the Generic Propecia medicine for hair fall. It helps to reduce the hair fall and increase the hair regrowth. The cost of this medicine is very cheap in online pharmacy.
Generic Propecia Effective Solution to Hair fall and Male Baldness Generic...
Mar 24, 2014 | Health & Beauty
Blade stuck in nutribullet
I took it apart by removing the rubber spindle and three small screws. Then soak it in vinegar and rinse to remove food gunk. Lastly, re-lube with cooking oil (I used olive oil) by pouring onto back shaft and spinning the blades to suck in the oil. Reassemble. I still have to replace mine as the spindle is loose due to the bearings being worn out but at least it is useable again until then.
Feb 21, 2013 | Magic Bullet Nutribullet Blender
55 rancher leaks thru the gas tank vent
a small amount of fuel leakege shouldnt hurt anything most gas tank vents are in the fuel cap if so replace cap
Nov 15, 2011 | Husqvarna Chain Saw 20" Bar
Bike will not start because its flooding profusely.so much so, it comes out the exhaust pipe . help
If you have a vacuum petcock make sure the diaphragm does not have a hole in it causing fuel to bypass the fuel petcock.
Note: always turn your fuel off when not riding. Not turning off your fuel petcock might cause your engine to fill with gas. Make sure your oil is not contaminated with gas. If it is you will have to do an oil change. It is possible that your air filter is now soaked with oil.
Next you may have to take your carburetors apart and clean them. They could have gummy gas in them causing the float needles to stick open flooding the engine. When cleaning inspect thew needles for wear, damage, and bad rubber shut off tips and replace them if necessary.
Mar 20, 2011 | Honda CB 100 Motorcycles
Husqvarna 55 rancher-just put new piston ring and cylinder.saw start right up and idles.when i try to acellerate it bogs and try to stall.when I let off gas it idles fine again.I tried turning mixture...
The plastic carb mount has a hole and a slot, this is the pulse channel from the cylinder to work the pump diaphram in the carb, if you look behind the plastic plate there is a tube that fits into the cylinder under the black induction rubber, this feeds a positive and negative pressure to the carb as the piston rises and falls, make sure you have re fitted the small seal in the cylinder that seals this tube or you will have big running problems.
Let me know if you need more help.
Mar 02, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
The rubber part that goes in your ear has fallen apart but the rest of the 330 works perfectly. Need new earpiece.
I'm sorry, Plantronics does not offer a replacement ear tip for the 330 headset. I will include the link to a webpage for Bluetooth headsets below.
Plantronics Bluetooth Headsets
Good luck from Headsets Direct!
Feb 13, 2011 | Plantronics Explorer 330 Headset
My 96 jetta 2.0 is leaking oil from the top of the oil filter mounting area where the water hoses connect to it.it looks like it has two or three pieces bolted together might be plastic.can I take apart...
The oil is most likely leaking from the oil cooler seal. The oil cooler is the square aluminum piece that the oil filter screws onto. To replace the seal, remove the filter, remove both coolant hoses that attach to the cooler, remove the nut that secures the cooler to the block and slide the cooler off the tube. Replace the rubber o-ring seal which is available at the VW dealer. It's inexpensive. Replace everything in reverse order. Good luck
Dec 31, 2010 | 1995 Volkswagen Jetta
How many qt of oil dose the 87xr600 hold.
it holds 2.3 liters of oil,
but you should drain the old oil first for best performance.
the drain plug is on the left side
it is also a good idea to change the air filter,
but if its not too old you can soak it in gas,
when the filter gets old it falls apart.
i have an 85 xr500.
Apr 23, 2009 | 1987 Honda XR 600 R
Garden Logo
184 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
