Does your battery indicator go low? Sounds like a low charged or bad battery. The signal looks good until you start dialing (transmitting) then the battery voltage drops causing low signal and disruption. Try a nother battery for a test. If the unit has been dropped the circuit board is damaged but you can easly test that with a known good battery.
