My Paslode air framing nail gun every 6 /9 nail will leave the nail up about 3/4 inch. What could be wrong?
If you're rapid-firing, this will happen. You need to let the air chamber fully refill before shooting again.If your gun says "maximum 120 psi" then set your air at 120#. If you have a slow compressor, get one made for the job, or be satisfied with carrying a hammer. You need quicker recovery, or your gun needs servicing/cleaning by a Paslode mechanic.
Your air pressure is dropping everytime you fire. It sound like your compressor is not cutting back in untill it to low. Not giving your tool enough continuess pressure. Your compressor cut in pressure should be around 90-100psi no less. and your max. pressure no more then 120psi. (Make sure your regulator is set at 110psi)
good luck...!
