SOURCE: Ice Maker Not making Ice
Water is in the tray and you have freezing temps? Can you tell me a little more? The flashing red light began when the ice tray filled and did not freeze? Let me know when possible, Thanks JT
SOURCE: kenmore side by side ice maker
There are as you can imagine many possible causes for you no ice condition. I will give you the most common problem for the year model you have. I hope this helps you.
You will need to remove the ice maker from the freezer compartment to check it. Once it is repaired if the following information does help, and you reinstall the ice maker, it should go through a cycle automatically within an hour of your reinstalling it in the freezer compartment.
Once you have the ice maker out of the freezer compartment you will need to remove the white cover on the end of the ice maker and look at the center of the large white gear. If the part inside the hole in the center of the gear is broken or looks twisted, you will need to replaced the module. The module is the part that has the large white gear and is held in the ice maker by 3 phillips head screws. It only comes as an assembly. You can't get just the little broken piece.
supertechks
Please don't forget to rate me
SOURCE: Kenmore Ice maker
It should have made at least one batch of ice by now. Make sure the water is on to the ice maker. Also the water line should have the air bleed out of it. It might have opened the solenoid valve and only got air.
SOURCE: fridge: not making ice, no water in ice maker
look to the water inlet valve behind refrig sound like you got a frozen line, or a bad solenoid
SOURCE: Ice maker not working Kenmore model 106.55226400
Look for an ice cube lodged in the fingers IM. Get a hair dryer and melt that dude. No ice cube? Add some water to the IM mold. If it kicks out some ice but makes no more then you is gonna need a water valve. If it don't kick out no ice then you is gonna need a ice mold thermostat. Either one is very easy and cheap to fix. let me know Kimosabe.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
