Question about Tilia Foodsaver V835 Vacuum Sealer
How do you seal the Foodsaver snack and sandwich boxes with the Foodsaver unit
    Problem Solver:
  • 17 Answers
2 Suggested Answers
6ya staff
SOURCE:
Lee Eismann
  • 88 Answers
SOURCE: Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
When ready to seal red light stays on
Seal 200 lights - Photo.net B&W Photo - Printing & Finishing Forum
photo.net > ... > Prints & Print Presentation
Jul 29, 2004 - 4 posts - ā€Ž3 authors
I'm sure one is a ready light but would really like to know the details. ... I have the Seal110S unit and the red (really orange) light stays on when ...
SmartSealā„¢ V3800 Series at FoodSaver.com.
www.foodsaver.com/...sealers/smartseal.../vacuum-sealers-help-and-...
TiliaHow does the new FoodSaverĀ® with SmartSealā„¢ Technology sense the ... My unit isstuck, it will not open, and unit is not allowing me to feed bag into unit to ...
Quickstart Guide for Hospital Staff - Creche Innovations
crecheinnovations.com/new/wp-content/.../Quickstart_Guide_2012.pdf
Seal the blue zipper tightly. Place feeding into inner bag. Seal the ... Ready. When red light is on. • Warming is occurring. When green light is ... light stays on.
What Causes the Brake Warning Light to Come On ...
Jan 05, 2016 | Cars & Trucks
The Vac runs and runs but does not seal. Can you order a replacement seal unit in Canada and where?
Practically speaking, before you start thinking about spending money on replacement parts, please visit here:
http://www.foodsaverblog.com/
You will see a comprehensive list of models and prices.
Then you can decide what to do.
You can also check here: http://www.foodsaver.com/Index.aspx for your nearest retailer of parts and supplies.
May 23, 2011 | Tilia FoodSaver VAC420
My sealing gasket is broken and it will not seal my food anymore. model 1050
Replacement parts for your product may be ordered online here:
http://www.foodsaver.com/Category.aspx?id=r
If you are unsure which gasket to order contact FoodSaver via their website:
https://secure.foodsaver.com/ContactUs.aspx
Feb 08, 2011 | Tilia FoodSaver V2240
The V2240 does not seal or vacuum at this particular step. The motor runs, the unit buttons are working but the vacuum, sealing action does not work..... Any ideas ..... And yes It was plugged in !
It's possible that liquid is getting into the sealer or the seal is dirty. Here's a link for a pdf that explains possible problems and solutions.
http://www.foodsaver.com/Manuals/MANUALS/T000-32030_44_65900646.PDF
Dec 11, 2010 | Tilia FoodSaver V2240
I need a owner's manual foodsaver compact fc-no-202412 i dont no how lang to l hold it down to seal the bag.model foodsaver compact .f.l.a.e.m.nuova.s.r.l
Well you many please follow the below link to get your manual -
http://www.foodsaver.com/manuals/FoodSaver/T000-32030_English.pdf
Check out page number 4 on this manual to know the time to seal the bag.
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 | Tilia FoodSaver V2240
Dolphin Dive Center
May 17, 2010 | Tilia FoodSaver V2240
V3460: no response when pressing seal and inserting bag. What should I do? Thanks
  • Assuming that the unit is plugged in and the plastic bag is in the proper position.........
  • Press firmly and equally on both sides of the cover (where the three raised ridges are on each side). The 2 micro switches that start the vacuum motor are located there and require firm pressure to operate properly.
Jan 20, 2010 | Tilia Foodsaver V835 Vacuum Sealer
Foodsaver V2490 will vacuum but will not automatically stop and seal. Can you help
I experienced the very same problem. Pulled out the two foam seals, rinsed them under a cold water tap, wiped off with a tea towel, reinserted,
Nov 17, 2009 | Tilia FoodSaver VAC420
Sandwich maker recipes
Found this on another website... not sure where... just had it copied to my word document... but here it is.
Warm up sandwich maker first…. Then spray with cooking spray.
Fruit pies
Two pieces of bread and apple pie filling (2 Tbsp)… cook 2-4 min Sprinkle with cinnamon and sugar when done.
Hot pocket
Ham and cheese
Breakfast
Egg Sandwiches
Egg Bacon and Cheese sandwiches
French toast… batter and cook, sprinkle with cinnamon and sugar? Cover in syrup
Pizza pockets
Cheese sauce and pepperoni
Mexican Fare
Using Tortillas add meat, cheese, or peppers
You can use…
Pancake mix
Muffin mix
Cornbread mix
Stir and pour into the sandwich maker Cook until done a few minutes.
Jun 30, 2008 | Salton Snack n Sandwich SA8 Sandwich Maker
Need to find a product manual or guide for this item.
Cannot find the product manual for my Salton GR 70 Fusion Grill....is it possible to download one?
Jun 16, 2008 | Salton Snack n Sandwich SA8 Sandwich Maker
Tilia Foodsaver V835 Vacuum Sealer Logo
448 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Sheldon Dedek
Vitally Alcher
Bonard Allen
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
