Spirit Esprit ET4 Treadmill Logo
Posted on Aug 10, 2009
Error 4 Deplay showing Over current
Friend,
I have treadmill with 2.75 hp dc motor...........it was running very well till last month when i changed the belt and know getting new trouble as soon as I start the treadmill, it starts for a seconds and stops and started showing Er 4, over current...........and it stops..............and technicians are saying that the PCB is fine.
Please help me.......I think PCB is leaking current somewhere....please help me.
Anonymous
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Oct 01, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
33
Questions
0
Helped
36373
Points
51
Hai,
error4, display board maybe not fine
REEBOK GT30 TREADMILL. It has ERROR E2. What does this mean please?
E2 Error usually indicates that the treadmill is overloaded and applies to various models like TR150, TRX1000 and TR 200. To fix this problem, check if your treadmill motor is overheating. Signs of an overheated motor include; grinding noise, motor produces a burning smell and inconsistent operation speeds.
Treadmill repair : r/fixit
Reddit · r/fixit 3 comments · 4 years ago Hi i have a reebok one gt30 treadmill bought in 2016. Recently at ... Start googling error codes and find out what E2 means. Upvote 2
Which part of my broken treadmill should I try replacing? - Reddit
Apr 18, 2020
Urevo 2-in-1 giving e10 error message- did you encounter this ...
Oct 10, 2022
Need help with Sole F63 treadmill error code - Reddit
Nov 21, 2022
More results from www.reddit.com
Reebok jet 300 treadmill e02 error - motor output dc is 11v on ...
All About Circuits https://forum.allaboutcircuits.com > threads > reebok-j...
Jan 9, 2023 - It seems to me to be a problem in the circuit that gives feedback to the processor about the voltage in the motor, error02 and does not arm the ...
Missing: GT30 ‎' Show results with: GT30
Treadmill Support - Reebok Fitness
reebokfitness.info https://www.reebokfitness.info > treadmill-support
View user manuals, assembly guides, instruction books, and technical support videos for all Reebok treadmills, including how to reduce static shock.
How to fix error code 6 on a roger black treadmill?
1)E00 Safety Key not in the position Re-locate the safety key in the correct position.
2)E01 No signal to Controller from the console
A: Check the Main Controller Wire
B: Replace the PCB Board
3)E02 Motor communication error
A: Check the wire from motor to controller
B: IGBT breakdown, Replace the controller
C: Check the power voltage if 50% lower than rated voltage
D: replace the motor wire or change motor
4)E04 Incline Motor communication error
A: Check the wire from incline motor to controller
B: Replace the incline motor
C: Replace the controller
5)E05 Over current protector
A: Overloading or over resistance,
restart the treadmill
B: Transmission parts seized up, check the parts
C: Replace controller
D: Motor breakdown, change the motor
6)E06 Motor Open Circuit.Connect the Motor link
7)E08 IC Driver Error. Replace the IC driver or change the
IC driver
8)E09 Folding up protect.
A: Do not fold up the running deck when treadmill in is running
B: If the running deck in laying position and show E09, you need to change the controller
9)E10 Motor instantaneous current abnormal
A: Adjust the torsion potentiometer of the Controller to lower
B: Motor Breakdown, change the motor
10)E11 Overvoltage protector Voltage over 270v (for 220v) or 150v (for110v) -- turn off the treadmill and check the power source
11)E13 No signal to console from the controller
B: Change the controller
12)E14 Lower voltage protector Voltage lower than 160v (220v) or 70v (110v) -- turn off the treadmill and check the power source
Pro-form 450cx
If the battery + and - polarity are proper and the motor operates on DC current; it should work OK. The reason a motor fails is if the coils burn out, and that can happen if the polarity is reversed in error, alternating current was applied to a DC device, or a Power Surge damaged the components.
Motor error messege on E25 sole ellipticle
proceed according. God bless youDescriptionThis error monitors the treadmills power bit reading. Power bits indicate the relative time that themotor controller drive circuit is turned on. Therefore power bits is an indication of the amount ofpower the load is demanding from the motor controller. The treadmill software sets a maximumallowable power bit limit. Error 25 indicates that the maximum power bit limit is being exceeded.Possible Causes1. The running belt and/or running bed is badly worn.2. On treadmills utilizing an SCR motor controller, a leaky or shorted drive motor filter capacitorcould raise the current demand sufficiently to cause the error 25.3. On treadmills utilizing an SCR motor controller, a leaky or shorted drive motor inductor couldraise the current demand sufficiently to cause the error 25.4. A shorted or de-magnetized drive motor is causing the high power demand.Possible Remedies1. A clamp-on A.C. ammeter must be used to determine the amount of A.C input current beingdrawn by the treadmill under no load and loaded conditions. The current readings can beused to determine the condition of the running belt and/or running bed. These same readingsshould be taken on a similar unit with a known good running belt and running bed. Thosereadings can then be used as a benchmark for future use. Replace the running belt and/orrunning bed as required. Remember, many running beds are double sided and the bed canbe flipped over rather than being replaced.2. A clamp-on ammeter should be used to measure the A.C. input current at no load. The filtercapacitor should then be electrically isolated from the drive motor circuit. The drive motorleads must be kept intact so that the drive motor will operate with the filter capacitor removedfrom the circuit. The no load A.C. input current should be measured again, if the A.C. inputcurrent is significantly lower, replace the filter capacitor.3. Use the same procedure as in step 4 above, except remove and isolate the inductor from thedrive motor circuit instead of the filter capacitor.4. A known good drive motor must be substituted for the existing drive motor.
I have a herritage t101, it displays the Ls error and has no drive whatsoever but was working a few month back
The SCR lower board is designed with diagnostic LED lights. The LED's are color coded according to
their specific function. Green indicates a properly operating treadmill; the green lights should always
be ON when power is supplied to the treadmill. Yellow indicates a treadmill function. Red indicates a
treadmill malfunction. Here is a list of each LED and what it signifies:
MOTOR (yellow) - The MOTOR LED illuminates when dc (direct current) voltage is sent to the drive
motor. The LED gets brighter when the dc output is increased.
RLC (yellow) - The RLC (R = Reactance / L = Inductance / C = Capacitance) LED illuminates when
the filtering system is properly working. The filtering system includes the capacitor and filter choke. If
there is a short in either component then the RLC light will not come on.
DN & UP (yellow) - The DN and UP LED lights tell us if the elevation DN and UP relays are
functioning properly. When the LED lights, it tells us that the relay has energized and is sending high
voltage (110vac or 220vac) to the elevation motor.
AC PWR (green) - The AC PWR (Alternating Current Power) illuminates when AC line voltage is
delivered to the treadmill. It then passes through the in-line fuse (110)/s(220) and lights the AC PWR
LED.
+12V (green) - When the proper AC voltage is delivered to the treadmill, passes through the in-line
fuse/s, through the full wave bridge rectifier (changes AC to DC), through the transformer (steps down
DC to +12vdc) then the +12V LED lights.
This the board LED, who control the signal for Main Motor+Elevation Motor. You must see, the LED DN+ UP( both will be Lit) in any position down or Up.
2) The RELAY board is designed with diagnostic LED lights. The LED's are color coded according to
LED.
VDC (green) - The VDC LED will light when it receives DC voltage from the DC power supply.
UPSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation UP relay. This low voltage dc is what energizes the coil of the relay.
DNSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation DOWN relay. This low voltage dc is what energizes the coil of the relay.
BELTSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper
display board to the belt (motor start) relay. This low voltage dc is what energizes the coil of the relay.
SPD (yellow) - The SPD LED flashes on and off (relative to speed) when the speed sensor is
operating properly.
PWM (yellow) - This LED will light when the upper board is sending a speed signal to the PWM.
Both the PWM LED and BELTSW LED must be lit for belt movement.
Finally this this Relay Board, the Each Led will be Lit, for any Relai control for DN down, or UP elevation motor. Use the contact cleaner, you can find it in R .Shack.
see the diagram attached.
Tunturi t7 showing error 20.
Try to RUN the sotware calibration for diagnostics.
This means user is heavy standing in the drive belt.
Causes: drive belt is worn, brusher motor faulty, motor faulty, motor controller board faulty
Remedies: use AC. clamp for drawn currente entering to the treadmill. Repair brusher and motor. Replace motor controller board.
God bless you.
see the block diagram
2helpful
2answers
Error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Precor 9.4 Treadmill Incline Problem. When incline is changed manually there is no problem. When it changes automatically during the preset programs there is an awful noise and I have to shut it off to...
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
1helpful
Treadmill incline error
Try this, it fixed it for me, if it doesn't work let me know
3answers
HP LASERJET 4 PRINTER
57 (or 57.1) SERVICE Message (Main Motor
Failure)
The 57 SERVICE indicates that the DC Controller PCA detected a
general motor failure. The Main Motor drives all moving
components in the printing process. The Main Motor is a 4-phase,
DC servo motor controlled by the DC Controller PCA.
The formatter detects a Main Motor failure when:
• The Main Motor does not come up to speed within one second
of receiving drive voltage.
• The Main Motor deviates from the correct speed for one second
after reaching the correct speed.
Main Motor Functional Checks
• Inspect the gear train for debris that would block the free
operation of the gears.
• Check the gears in the Toner Cartridge for wear and binding.
• Reseat J211 (or J214 on the HP LaserJet 4 Plus/4M Plus) on
the DC Controller PCA, and the main connector on the Main
Motor Assembly. Refer to Figures 7-16 and 7-17 for the DC
Controller PCA connector locations.
• If the problem persists, check that the +24B Voltage is present
on the DC Controller. If the voltage is not present, replace the
DC Controller. If the voltage is present, and the motor does
not rotate, replace the Main Motor Assembly
Top Spirit Exercise & Fitness Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Spirit Exercise and Fitnes Expert? Answer questions, earn points and help others
