Cell Phones Logo
Posted on Aug 10, 2009
Micro sd memorycard
I have a 1gb micro sd memory card that says that it needs to be formatted when i double click on the removable disk icon. when i click format, it says disk cannot be formatted. please help!!!
Anonymous
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Aug 11, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
0
Helped
2979
Points
34
There are virus on our sd memory card. you must scan first and then format it. be sure scan and format in the computer.
1helpful
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
7helpful
2answers
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
2helpful
6answers
Remove write protection of my memory card
i have a my memory no four met of tha sho unable to fourmet write proteket
Micro sd 2gb tidak bisa format
Hallo scorpio, semoga solusi ini membantu
If the micro SD format fails, do not you repeat the formatting process. Because it will exacerbate the damage to the micro SD. Follow the steps below. Good luck.
Step One:
Step Two:
If the second solution does not work, it means your micro SD damaged firmware. Based on experience, one of the causes of damage to the firmware is, the formatting process is done repeatedly, but always failed.
My Sandisk 'Wake up your phone' adapter & the micro one won't let me add music or anything else. It says that the disk is write-protected. Help?!
Micro SD write protect means there is damage to the firmware. Micro SD write protect, the data can be saved. Follow these steps:
Step One
After all data is secure, do the process repair micro SD.
Based on experience, the following methods can be used to repair the damage: RAW file system, used space 0 bytes, free space 0 bytes, micro SD can not be in the format, micro SD corrupt. To write protect a micro SD cases, 40% probability of success. But, you can try it. Good luck.
Step Two
Using the HP Drive Key Boot Utility, the first way
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
I have a 2GB micro sd card,but when i check it into my cellphone,my memory card is error.What is the problem of my memory?
Step One:
Step Two:
2answers
When I enter my memord card in nokia 311 it say the operation is failed and the memory card is not formatted.how to remove virus from my memory card and replace my music and Image.
Step One (save data)
When do the data recovery process, you can find the cause of damage to the micro SD.
Cause of the damage the virus infected (solutions: see method 1)
When saving data, be careful, do not recover the virus file. You must choose the proper file for the recovery.
Cause of the damage bad sectors (solutions: see method 2)
Damage to the partition table (solutions: see method 1)
Micro SD write protect. Characteristics: (solutions: see method 3)
1. Micro SD can be opened, the data can not copy and paste (from the micro SD into a computer, or from computer to the micro SD). When the format, the message "Removable media write protect".
2. Micro SD can not be opened, and when the format of the message "Removable media write protect".
Step two (repair micro SD)
Method
Method 2
Method 3
3answers
My 2gb san disk memory card suddenly stop working when i have downloading songs from internet
i think it has got virus.just format it.
Step One:
To save data, use EASEUS Data Recovery software (free version - 1GB of datarecovery). how:
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3,4)
Step Two:
4. If you are using Win Vista or Seven, double click the file cp006049.exe - selectextrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - selectdrive - Next - Create new or replace exiting configuration - Next - Hard drive - Next -Create new file system - Next - wait until the process is completed - Next - Finish.
I have a 1GB corsair SD flash card with photos; only 75% deleted and I get a write protection message. Its used in Lumix DMC-FZ20 and it shows no photos on card but the PC shows 25% full. How do I...
just format it and if you want your data then,
Step One:
Step Two:
My micro sd 512mb memory card asking password, i have forget it. how to open or format my memorycard
If you're on a mac, use disk utility to format it. If you're on a PC, right click the drive and click "Format..."
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
