Upto my knowledge, IRiver-E100 Supports "WMV" format but there may be some restrictins like bit-rate, frame-rate..(WMV1,WMV2,WMV3..)
There is a vedio convertor available for this, Here
That might help you.
Regards,
Waqar.
Sorry, I am unable to catch you words correctly.still not working after formatting to *.avi
Have you converted the vedio format to AVI?
MPEG4-SP (less than 30fps, 2Mbps, 320 x 240) WMV9 (less than 30fps, 768kbps, 320 x 240)
Iriver supplies Movie Converter to transcode videos into an E100-compatible format and recommends iriver plus 3 to transfer them to the player. If you are unsatisfied with Movie Converter's performance in the past, I would recommend skipping it entirely and using either CloneDVD mobile, iriverter, or SUPER.
Regards, Waqar.
No Man, you have to convert in into one og these;
MPEG4-SP (less than 30fps, 2Mbps, 320 x 240) WMV9 (less than 30fps, 768kbps, 320 x 240) Iriver supplies Movie Converter to transcode videos into an E100-compatible format and recommends iriver plus 3 to transfer them to the player. If you are unsatisfied with Movie Converter's performance in the past, I would recommend skipping it entirely and using either CloneDVD mobile, iriverter, or SUPER. Regards, Waqar.
You can't post conmments that contain an email address.
it is easy and simly there are two methods of formating code formating -when phone is on the switch on mode dial *#7370# then ask for formatting and ok
the second method is hand formating --first switch of your phone then press the star(*) three(3) and call button holding these button and switch on the screen displays blank white screen for sometimes and then on .
these are the two main methods of formating symbian phones it is 100% working guarantee
Hi, The problem may be with, 1. Graphics driver installed in your laptop 2. The Video file which you are trying to play may got corrupted. 3. The player you are using to play the vedio may not have proper codec to play the file solutions: 1. Reinstall the graphics driver for your laptop 2. Try playing some other vedio files 3. Install VLC player and try playing using this player as it supports most of the vedio formats and even plays corrupted vedio files. I hope this is helpful to you.
I had the same problem and struggled with it for some time. I forgot the format feature on the device itself and kept formatting from my pc. This won't work.
The solution:
1. Unhook your device from the pc by pulling out the USB cable.
2. Click the "Menu" button 1 time (found on the back of your NW-E105 player).
- This will show "Display"
3. Click the " |<< " button 3 times (the button to rewind track).
- This will show "Format"
4. Click the Play/Stop button 1 time.
- This will show "Format: N"
5. Click the " |<< " button again 1 time.
- This will show "Format: Y>
6. Click the Play/Stop button 1 time (wait for "really?" prompt), click it again.
Now your device is formatted and will play the files you add to it.
hi! i hav a motorola motorokr E6 in which i am not able to play vedio files exept in .3gp format. can u plz suggest how can i play vedio file of other format?
thanks
problem with software?
how can i repair
i convertsd with any vedio converter
to *,avi
