There is a lever on the front of the scanner (I think in the bottom left) which allows you to change from manual to multi page feeding. You should be able to correct the problem by moving that lever to the positiion where there is a picture of three sheets of paper rather then where there is one sheet.
If you have it set to certain paper weights or manual feed that is all you will get. Change the settings from the printer monitor back to normal weight paper or text not high quality graphics and it should feed again.
