The F2 E0 error indicates a communication error at the key pad. The key pad could be faulty. There may be a problem with the wiring between the key pad and the control board. The last possible issue is a problem with the oven's electronic control board. First unplug the range (or turn it off at the circuit breaker) and take a look at the wiring. Disconnect and reconnect the wiring harness between the key pad and the control board. Check for any damaged wires in the wiring harness or corrosion where the wiring harness connects (and in the plugs) on both sides. If the wiring is okay, connect the range to power and wait to see if the message recurs. If it does, you'll need to replace the key pad. If the error recurs, then replace the control board when that is sold as a separate assembly.
There is a parts diagram and pricing list for the RF265LXTB1 here: https://www.appliancepartspros.com/parts-for-whirlpool-rf265lxtb1.html . On this range, the replacement key pad and the control board are sold as a single unit. It's part 11 on the Control Panel diagram.
I hope this helps.
SOURCE: whirlpool electric range RF361 bxdn 0. error codes? PF?
hi Jon
look on the back of the unit, there should be an envelope that has a paper in it, that paper should tell you what the code means.
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
SOURCE: Whirlpool Range RF367 Error Code F1E1
Hi Rooster,
This it the proper solution for your problem:
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
I would need the complete model number to give you a price and part number for the ERC. Just let me know if I can help you more.
Mike Anderson (Owner)
Anderson Appliance
(865)945-3808
SOURCE: Whirlpool Gas Range E2 F3
I HAVE A WHIRLPOOL GAS RANGE MODEL NUMBER SF379LEMS.OVEN WILL LIGHT UP BUT AFTER TEN MINUTES IT WILL KICK OFF ANF ON ON ,THEN AFTER AWHILE I WILL JUST SHUT OFF.ANY SUGGSTIONS. ADAM
SOURCE: GE Range Model GRCR3825ZWW-1 DOOR error code on range display
The door latched Micro-switch is not working or is dirty.
Remove the back panel, in the middle of the back there will be a metal arm that moves in and out when self cleaning latch is closed and opened. This arm pushes two or more Micro-Switches in the back, they are dirty or not working and need replacing.
All parts come with a 365 day, any part, any reason return policy.
