SOURCE: Shift lever
It sounds like you may have a faulty shift interlock solenoid. It is under the center console. You can expose it and see if it is getting voltage when the vehicle is on and you foot is on the brake. If it is, replace the solenoid. If it isn't, you may have a faulty relay.
SOURCE: Transmision Shifting Problem
Was the fluid you drained red or black? did it smell like trans or gear oil? With linkage disconnected, could you put trans in park by moving the lever on the side of the unit? Oil condition is likely a separate issue...most "blown" transmissions generally have normal operation of shift, it just dosen't do what you tell it to. two things likely going on are: linkage problem and likely in need of fluid/filter change.
SOURCE: I just purchased a used Ariens sport zoom 1440.
Change the oil and air filter. Look for grease fittings on all moving parts and give them a shot.
SOURCE: Cable from parking brake release handle not connected at pedal.
Get the "Shop" to come back out to fix it or sue the *** off them for leaving you with a dangerous car.
No handbrake is an offence !!!
SOURCE: I just installed mulch kit on my Ariens 34
i'm wanting to install a mulch kit too but it seems diffecult. hoew do you access under the mowing deck to install everything?
