SOURCE: craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
SOURCE: Blades do not spin fast enough to cut grass
If you got the right oem belt,ta\han you can look at the end where the cable attachs to spring and you should see a double nut adjustment loosen nuts and adjust to put more tension on the belt when you put lever into gear for blades to turn then retighten them .
SOURCE: Homelite trimmer runs, but can't run attachments very fast.
Doesn't sound like piston and ring problem. Sounds more like the flex shaft that connects to the engine may have an end that is worn not allowing for the extra load when you connect the attachments. Check the ends of the top flex shaft.
SOURCE: i have echo 230 trimmer that runs on idle and wide
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
SOURCE: have a ryobi rlt 30 cd and the spool wont spin fast enough
hgffggkgjgjgbTry taping the bottom on a hard surface;HARD!;;;;;;;bjjjjjjkjjjjm4454541joojojojlj That did the trick for me for some reason it doesn't grab and it gets lose were it won't spin fast bearly cutting a blade of grass.
