SOURCE: after using Word (Office 2007)
go to your control panel and then go to your regional and language and make sure all the setting are set to english, on the languages tab then details make sure you only have 1 keyboard setup in there, delete any others
SOURCE: I cant use the apostrophe
Sounds like the keyboards a bit confused try going to control panel then under region and languages click on keyboard and select another countrys keyboard layout and click apply then change it back and apply again. I cant guarantee this will work but its certainly worth a try. Please let me know if this works good luck.......cheers from Scott and plz vote
Testimonial: "Yeah, the language was set for English and French; hence the confusion with the keys. The English-Canada-US has to be selected to avoid the problem."
SOURCE: Problem with a Dell Keyboard
Notice that the Language bar appears on the taskbar. When
you position the mouse pointer over it, a ToolTip appears that
describes the active keyboard layout.
The United States-International keyboard layout is selected.
Testimonial: "Thanks.....this solved the problem :)"
