When I start my D2, all lights flashes as usual, but a few seconds later, they flash again. Then everything freezes and no keys function. Even shut off will not work properly.
I was capable to update the firmware though (now 1.09). But it didn't solve the problem.
Is there a way to reset the D2? A combination key I need to press or a reset switch that I don't know of?
Very unfortunate that the problem occured at a party last night with tons of people expecting a competent DJ...
Thanks for the help
sorry i got another post mixed up(i was running four and yahoo, google) try using different mp3 players or ipods.also try turning on without ipod hooked up.its more than likely a software issue so it might be best to look for a flash utility and put it on pendrive. if none of these work then there might be a fault on the setup or something is going bad in the machine. i know that a old friend fixed theres by formatting there mp3 player. here is a link to a manaul i believe to be the dj machine
http://74.125.47.132/search?q=cache:eDHg...
sorry for the confusion and feel free to give a bad rating,i don't mind,
Maybe your ipod is almost full?. After I pull out some songs from the ipod and leave about 10% of the memory free, it never happend again. good luck.
I'm not sure I'm following you here. The D2 Director is a stand alone unit and doesn't plug into a computer.
Do you have found a solution ? Cause I have the same problem...
Please help me !!!
