Question about 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 5901, Ford 2008 6.4/ When I use the trucks door keypad
Viper 5901, Ford 2008 6.4/ When I use the trucks keypad it will unlock the doors but make the alarm go off. How can i instruct my installer on how to fix it this.
Thanks!
    Scholar:
  • 129 Answers
If you use the viper remote to arm the alarm, you MUST use the viper remote to disarm the alrm prior to opening the door. The only REAL solution is to add the keyless entry feature to the viper system, and quit using hte factory remote all together.
Posted on Aug 09, 2009
6ya staff
SOURCE:
How do I reset keyless door entry that is in lock out mode
Viper Keyless Entry Systems
https://www.viper.com/car/keylessentry/
Viper is the industry leader in keyless entry systems. Add the convenience of keylessentry to virtually any vehicle - even vehicles without power door locks!
Alarms, Remote Car Starters, Keyless Entry & Locks - JC ...
www.jcwhitney.com > Audio, Video & Electronics
20 out of 32 products in Alarms, Remote Car Starters, Keyless Entry & Locks ..... ofKeyless Entry & Car Alarms allow you to lock and unlock power door locks.
How to program your keyless entry keypad - Ford Ownerhttps://owner.ford.com/.../locks.../how-to-program...Ford Motor CompanyDiscover how to lock and unlock your doors and how to program memory settings that will adjust seats & mirrors for each driver.SecuriCode™ Keyless Entry Keypad - Ford Ownerowner.ford.com/.../locks.../securicode-keyless-entr...Ford Motor CompanyLearn how to set a 5 digit SecuriCode on the Ford keyless entry keypad. ... Sign out. Register/Sign In · Your Vehicle. Service & Maintenance. Service & .... vehicle's SecuriCode keypad to lock and unlock your doors without having to use a key. ... Thekeypad will go into an anti-scan mode if you enter the wrong code seven ...How Programming Your Keyless Entry Can Make ... - Ford Life
Jan 08, 2016 | Cars & Trucks
Why won't it start vehicle?
[PDF]Responder LE Model 5701 Security and Remote Start ...
xtremetruck.net/file/1101-Viper+5701+Owner's+Guide.pdf
the year, make and model of the vehicle; vehicle license number and vehicleidentification number. All ..... One five-button/2-way Supercode Responder LE RemoteControl. ? .... Disarm. Unlock LED blink for one second with 2 Beeps. Remote. Start..... Long-time Viper system users will notice the following differences:.
Viper LED 2-Way Security + Remote Start System
https://www.viper.com/car/securityremotestart/.../viper-led-2-way-securit...
Viper's elegant new Responder LE transceivers mark a giant leap forward in 21st century vehicle security and remote start, and an evolutionary milestone for the ...
Viper 5901 remote start error fix - YouTube
? 2:38
https://www.youtube.com/watch?v=wsSorAf88nw
Jan 13, 2013 - Uploaded by Power2ThePeopleZ
5901 won't start vehicle; gives an error. ... or even try to open the hood. the door remains locked when you start the car with theviper alarm.
Help With Programming/Pairing Viper Remote - YouTube
? 2:49
https://www.youtube.com/watch?v=cgbQsZuVyt8
Dec 2, 2010 - Uploaded by Paul L
I have a two-way remote from my Viper 5901 system. ... The other car (one in video) has the Viper 5701 system in it. .... and then release 3) press the remote start button 2 times until pairremote is displayed 4)press and old ... I had the same problem that the remote won't pair with the system no matter what.
15964701 Viper 5701 2 way alarm w/ remote start won't
Jan 05, 2016 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My sst 7752v viper remote will not unlock my doors, it just beeps. I cant get into my truck without my remote... please help
how old is the remote is a question to consider. the batteries might just be too low to send a strong enough signal for the truck's transponder to receive. does the remote need to be coded to the truck if not more than likely its weak batteries. the LCD display doesn't need much power to light up, but the remote does to send the signal.
Aug 08, 2013 | 7752V Replacement Transmitter Supercode...
How to program a 7752V VIPER REPLACEMENT REMOTE
Open driver door.
Push and hold "f" key until remote beeps.
Push remote start button once so "pair" appears on screen. Push and hold "f" until remote beeps three(3) times to select pair mode.
Insert key into ignition an turn to "ON" position.
Push and release "valet" button on antenna, push again and hold until remote emits a series of beeps and displays "passed"
Feb 08, 2011 | 7752V Replacement Transmitter Supercode...
I have VIPER 5901 > how
The shock sensor can be adjusted by a Viper dealer.
The second part of your question does not make 100% sense, can you please reword and put in more detail.
Jan 31, 2011 | 5901 Security Remote Start System
Just baught a truck with a viper alarm, worked great then today i unlocked the truck with the viper remote and when i open the door the horn goes crazy for for about 1 min not the accual alarm! but at the...
Can be somewhat complicated to explain, particularly without knowing the make, model & year of the truck and which bypass was used to integrate into the factory systems. But here's one thing it might be. The Viper system is aftermarket obviously, when the alarm is triggered the siren with start to sound, and sometimes the horn will honk as well (depending on the vehicle and the bypass). If the siren isn't blaring that means the Viper system was disarmed when you unlocked the doors but not your factory security....or another way to word it is if only the horn is honking and no siren then you're factory alarm system isn't being controlled by the viper remote the way it should be. The factory disarm wire needs to be connected. It's a light green wire with a black stripe in a red connector in the Viper alarm brain. For anything more specific I'd need some more info on the vehicle. You can email me at jared@underground-audio.net if you'd like.
Nov 17, 2010 | 7752V Replacement Transmitter Supercode...
I have a viper 5901 installed on my 2008 Impala SS and every now and then the alarm goes off saying the doors are open but they are closed. why would this happen
This is happening because they used the cars domelight to set the alarm off when the doors are opened. When the cars computer goes into battery save mode and shuts down certain parts of the car, the domelight is one of them and a slight ground or 12 volt positive is backfed to the alarm and sets it off. This usually happens after 30 minutes. they should take the alarms door trigger and actually go to the cars door latch wires. The colors are:
gray/black - driver door tan/white - pass door lt. blue/black - back driver door lt. green/black - passenger back door
Aug 31, 2010 | 5901 Security Remote Start System
Installation of a Viper 5901 remote start into a 2001 Ford Explorer Sport
viper 5901 remote start alam installing it on a 1997 ford explore i need a detail wiring diagram
Mar 04, 2009 | XX-67A II LED/Valet Switch Pod
5701 VIPER 5701 2-WAY ALARM w/REMOTE START Logo
591 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
garyg7133
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
