I have a HE5t washer that is throughin a F32 code what does that stand for
Here's a solution from an old posting of the same problem in a different Kenmore washer:
F32 is the code for a Water Level Switch Failure.
1. Remove the top panel from the washer by removing thethree screws in the top back of the washer.
2.Inside the back rightcorner is a round plastic box, fastened to the side with a plasticsnap. In will have a wire connector and a small, rubber hose connectedto it.
3. Check to make sure all the connector wires areconnected and tight. Unplug washer for 30 seconds to reset it. If the cycle failsstill with the F32 code, you'll need to replace the Water Level Switch.
4. Ifthe Water Level Switch does not eliminate the F32 code, it then the machine controller may have failed.
