Device is about 6 weeks old and has occasionally lost its pairing.
try to make hard reset to both devices,
regards,
Daniel
https://www.rylwy.com/diy-magnetic-loop
SOURCE: Unable to set pairing between jabra bt 125 and bluetooth device
You simply need to hold the button down for a long time, it will flicker blue at first, don't let go of the button, and it'll turn blue for pairing.
SOURCE: old phone quit and blue tooth won't pair with new phone
Hold the volume buttons on the side while holding the call button for 10 seconds. It will reset the bluetooth and remove any other devices it may have been paired to. Then turn it off, back on and it will eventually stay lit blue and then you need to set it up through your phone. I hope this helps, I had the same problem and mine is working fine!
SOURCE: My bluetooth is not pairing with my Envy3. When I
Try turning your phone off and then on again.
SOURCE: I just purchased a Voyager
You will need to turn off your headset and then press and hold the power
button until the LED starts to flash red/blue, red/blue, it will stay in
this state for a few minutes.
Good luck from Headsets Direct - 800-914-7996.
Step One:
Prepare Phone-
Turn on Bluetooth
For most phones, go to Settings/
Tools menu and select Bluetooth
or Connectivity and select "On."
(Or see the user guide for your
phone.)
Step Two:
Prepare Headset-
Pairing Mode
Step Three:
Pairing-
Add Headset to Phone
For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device,
then Select "220Plantronics."
For passkey enter 0000. Headset
will flash blue when paired
successfully. It is now powered on
and ready to use.
Begin with headset turned off. Turn
headset on (hold call control button
for 2 seconds until the light flashes
blue) and it will automatically go
into pairing mode, flashing red
and blue. hope it works
regards
shaun
