As you probably know, the GPS device needs to get a satellite signal to determine its (your) location, before it can be used.
When the device is having difficulties getting that information, that message is displayed.
A common reason for not being able to get the signal is when there's physical barriers between the device and the satellites, e.g. when you're in a building, under certain covers where there's little/no line of sight between the device and the satellites.
Sometimes, even when this is not the case, the GPS has difficulties getting satellite signals.
So, getting an update (from the tomtom webiste) of the satellite locations can help. Just connect your GPS to the tomtom website, using tomtom HOME (the software), and get the QuickGPSfix update (a very small file) installed on your GPS device. It is suggested you update this data regularly ( as it provides a better location of the satellites, for the GPS device to search)
If you've already done that and the GPS still have problems locating the satellites, try to reboot the GPS. This can be done by holding down the ON/OFF button (for quite a while, e.g. 30 seconds or more) ... to shut the GPS down, and then turn it on again. Or, use a pin (e.g. paper clip) to press the "RESET" pin-hole, to turn it off, and start the GPS device up again.
Hope this helps.
SOURCE: MY TOMTOM ONE IS WAITING FOR A VALID GPS SIGNAL I
Turn on your tt and let it bootup. After it has booted up go to the map screen. On the bottom right where the bars are for satellite reception. Tap the bars this will take you to the screen telling you the device code etc. On the upper far right where the battery icon is tap the screen again. This will take you to a screen showing the satellites. If you see grey bars on the graph just wait awhile. Sometimes when your tt has not been turned on for awhile or you have turned it on after traveling a few miles it may take up to 30 minutes to get a lock.
Hope this helps
SOURCE: waiting for valid gps signal
Go to TomTom Home on your computer and do a update for your unit. In the update list you should see a GPS quick fix which helps the TomTom's aquire a signal faster. Hope this helps.
The GPS needs at least 3 satellite signals to operate.You are probably in a bad reception area. Move around a bit and try again until you see a signal array of 3 or more!
SOURCE: My tomtom one 130 will not pick up a valid GPS
Install Tomtom Home on your pc and connect your gps on it.Do not update the firmware yet, but ony the "gpsfix" program. If it does not work, try a reset by holding the power button for 15 seconds.Let´´s get in touch
SOURCE: my tomtom go 300 keeps reading
i've had the same problem,to fix it you need to update it,i connect it to the computer and go to tom tom home there you can get free updates,i do mine every month,this will fix your problem.
