SOURCE: LG GR727RB Top Freezer ok but bottom fridge is not cool
Hi softwaredude with an LG GR-727R refrig. The occasional build up of water on the bottom of the fresh foods sections tells me that the refrig is going through it's defrost cycle, but that the defrost drain is plugged. If you take the back off the refrig. you will see a plastic tube about 1/2 inch diameter with a few ribs on it going from the top of the compressor compartment to the bottom, which is a defrost water holding / evaporating pan. Look to see if that tube is plugged. If not, it is plugged further up, most likely where the defrost water drains off the evaporator (that the coils behind the freezer wall that do all the cooling). Take that back panel off and use a hair dryer to melt all the frost off. The frost is blocking air flow from the freezer section to the fresh foods section, thus poor or no cooling in the FF section. You should be able to spot where the defrost water is suppose to drain. If the water is not draining out, use a turkey baster with hot water to flush out the drain.
SOURCE: LG LRSC 26923TT Side by Side Refrigerator Problem with ice maker
We have the same problem with the ice cube tray. Repairman said the tray must be replaced every year as continual bending warps it out of shape. Replace every year and your problem is solved.
SOURCE: Inside top of refrigerator hot light don't turn off.
There is a service bulletin related to this, dealing with deformation / melting of the lamp cover. The fix is to change the lamp wire harness to one that now has a thermal protector incorporated in it (part number 6621JK2003B) along with changing the main PCB board to one that uses a larger relay for this function (part number 6871JB1423N).
In case you want or need to replace the following,
The lamp cover is part number 3110JA1096A and the lamp holder is part number 3034JA1009A
I tried to cut and paste a few photo's, but was unsuccessful. Sorry. Make sure to test that fans and light switches work after part changes.
SOURCE: Freezer and Refrigerator are not getting cool enough
there is more ice built up behind the panel
defrost is not working
