Had to disassemble because the cat dropped a toy in the toiled and it jammed the blade. Man, it was funky in there !!!! Wondering if we can/should use something like Rid-X on a regular basis to help keep the tank cleaner. Thanks
We have a maserator in en-suite which serves the toilet & shower, We moved in to house 6 years ago and it was already here. After having guests stay a couple of months ago the maserator hasnt worked properly. When we flush the toilet, the water rises and whilst the cistern is filling with water, there is a humming noise for a couple of minutes, then the water rushes back down and there is a clonk and the water bubbles back up through the shower plug hole.Any suggestions as to what this problem is & how to fix it please?
For poucha re blocked saniflo. Your symptoms describe a blocked saniflo outlet. As you flush the waste cannot pump out normally so back pressure builds up and the water bubbles back through any other inlet/ outlet (the shower). There should be a non return flap inside the saniflo to prevent this but its not 100%. Your guest have flushed something they shouldnt, and it has made it past the pump and into the 22mm pipework - remove unit and clean it & the pipes.
I would not use it. It's an added cost for stuff you'll just dump out. There should be more than enough bacteria in the system to clean it as much as it is going can be cleaned.
Charlie
