Dell Inspiron 1525 Laptop Jet Black  Logo
Posted on Aug 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Touchpad not working properly when the power cord is switched on
Hi
i got my dell inspiron 1525 in oct last year. its been a week now that i have a prob with my touchpad. firstly it dint work well whether the power cord is on or off. i tried a soln here and after i tried it, i was happy to see it worked out well.
but to my surprise, its only good when there is no cord but troubled while charging my laptop.
Pls help me out...
i dont wanna use a mouse and i cant even send it to dell service...
So tell me a fix-it-urself to make it work well again!!!
Anonymous
Level 3:
  • Master 3,940 Answers
  • Posted on Aug 09, 2009
Anonymous
Master
Level 3:
Answers
3940
Questions
0
Helped
1404618
Points
12062
First uninstall the touchpad driver in add/remove programs, reboot the system and see if the touchpad works better (Some functions may be lost like scrolling, but this is just a test)
Next go to support.dell.com, download the latest system BIOS and touchpad driver, install them and reboot, see if issue is resolved.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
399
Points
First of all disconnect all cables from your laptop, then remove the battery, in the battery compartment are two small screws, undo and place to the side, then open the laptop as far as it will open, unclip the plastic just beklow the screen, then unscrew two other screws holding the keyboard in place, then you need to remove the plastic surround to the keyboard, then at the bottom in a small cut out just above the touchpad is a small ribbon connector, remove the small black clip, clean the contacts and reinsert the ribbon cable and clip, your touchpad will now be functioning correctly.
Dell touch pad not working
The touchpad on a Dell laptop is usually located under the keyboard. Moving the finger on the pad moves the pointer on the screen. The buttons near the pad act as a right and left click. Windows includes a method to troubleshoot the touchpad. In addition, if the touchpad is still giving you issues, Dell recommends draining the "flea" power the standby power from the computer to restart it. Both methods are simple and only take a few minutes.
Open the control panel from the Start menu. Click on "Mouse." This will open a window with several tabs. On the first tab, click the touchpad to open a new window to change the settings for your touchpad. You can customize the settings to how you want your touchpad to work. If this does not solve your issue, proceed to the next step. Click the Hardware tab on the screen that pops up. Select the Dell Touchpad and click "Troubleshoot." A new window will open with the Windows Help and Support Center to bring you through methods for troubleshooting the touchpad. Follow the methods described until your touchpad is working properly. Drain flea power Shut down the laptop and disconnect all external devices, such as a thumb drive, headphones and the AC adapter power cable from the system. Take the battery out of the laptop. Hold down the power button for at least 5 seconds without releasing it. Return the battery back to the laptop. Power the system on. If your touchpad still is not working properly, call Dell for customer support.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=59EB83ED2E4B1243E040AE0AB7E1468E&doclang=en b> Dell Inspiron 1525 Touchpad That Is Not Working
Turn your Inspiron 1525 off and remove any power cables that are connected to the device. Close the computer, turn it over and slide the battery lock button down to release the rectangular battery from its compartment on the underside of the computer. Turn your laptop right-side up and open the computer so the monitor is facing you. Insert the tip of your flat-head screwdriver in the seam between the plastic keyboard guard and the side of the computer. The keyboard guard is located just above the keyboard. Pry up on the guard until it pops out of place. Be sure to do this gently, as you do not want to damage the guard. Remove the guard from the computer and set it aside. The two keyboard screws will now be visible underneath where the guard used to sit. Use your Phillips screwdriver to remove the two keyboard screws and use the tips of your fingers to lift the keyboard up from the top. Place the keyboard facedown over the touchpad and locate the thick connector ribbon that runs from the motherboard inside the computer to the back of the keyboard. Use your fingers to gently unplug the ribbon from the back of the keyboard and set it aside. Insert the tip of your screwdriver in the seam at the bottom of where the keyboard used to rest and gently pry it up. This will release the top plastic frame from the Inspiron, revealing all of the broken touchpad. Use your fingers to disconnect the thick ribbon from the side of the damaged touchpad and slide the touchpad out of the Inspiron. Slide the new Touchpad (available from your Dell retailer or online) in its place, fit the top frame in place and reassemble the computer in the reverse order you took it apart in.
http://www.insidemylaptop.com/replace-damaged-keyboard-dell-inspiron-1525-laptop/ Replace keyboard in dell inspiron
3helpful
3answers
My dell 1525 no power at all
Good luck with this colossal piece of junk from Dell. I had the same problem. Second Inspiron to do this. I ordered a new battery. The Dell techie was SO impressed that the battery lasted more than a year. It lasted a year and a half. Anyhow, new battery arrives, and it won't charge. They tell me it is probably the plug in and the motherboard. Nothing like spending over 500 to fix a computer that I paid 600 for that did not even live to see two years old. Did I mention that I will NEVER buy another Dell.
Hi my touchpad is not working...
it would be easy for you to get a usb mouse.you can just borrow and install the dell touchpad drivers from dell support website.this sould be fixed.
2helpful
Dell Inspiron 1525 not turning on
hi. I suspect that you have either a dead battery or just need a reset. unplug the power cord and then remove the battery. wait two minutes and reinstall the battery.
this will reset everything. now try turning it on. if it won't come on plug in the power cord and charge the battery for 30 minutes before attempting to power up.
I have dell inspiron 1525 and it is not working properly i was surfing the net and suddenly my laptop stopped working and shut down I turned it on again and all my drivers are not working properly my...
when u power up the computer press F8 key then enter in last know good configuration .
Then go to start menu and type in run "chkdsk /r"
then press "y"
then restart the computer then wait till disk checking completed then it auto restart and then winxp loads.
Tehn check all are working good or not.
Please let me know.
1helpful
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Laptop touch pad mouse does'nt work while charging
my toch pad dont work when my laptop is charging i have inspiron 1525
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
