Camera only used a couple of times and shows all menu icons on screen but otherwise all black. It flashes like it is taking a picture but shows a black screen upon playback as well. Is worth fixing? I bought the camera out of state so I can't take it back.
black screen and black screen and taking forever to show the main menublack screen and black screen and taking forever to show the main menu
AnonymousMar 19, 2014
screen is black Camera only used a couple of times and shows all menu icons on screen but otherwise all black. It flashes like it is taking a picture but shows a black screen upon playback as well.screen is black Camera only used a couple of times and shows all menu icons on screen but otherwise all black. It flashes like it is taking a picture but shows a black screen upon playback as well.
You can't post conmments that contain an email address.
the image in the LCD monitor will darken in strong sunlight or bright light. This is normal occurrrence in device CCDs and does not contitute a malfunction. This image will not be recoded when shooting still photos, but it will be recorded wihen shooting movies.Read you owner manual and adjust the MENU, according with your o. manual.Otherwise you must go the repair shop God bless you
Hi David: If you can check menu settings there, isn't the LCD screenviewer issue; then sound like a malfunctioning
CCD (Charge Coupled Device) image sensor... in both cases (LCD or CCD) this isn't a job that you could solve yourself; this wrong
include distorted
images or abnormal colors, scratchy purple lines, blank or black pictures,
and/or black videos with good sound being recorded on the camera's flash
card. I
suggest check this link for additional details in this previous solutions for an Defective CCD and next contact your Canon service. Istrongly suggest(taking intoconsiderationthe age of yourcamera) to
evaluatethe cost ofrepairversusthe
cost of anewcamerawith similarfeatures,before making afinaldesicion.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.
Sound like a malfunctioning
CCD-image sensor. Rare, but possible problem with your LCD screenviewer (I dont believed, if you can see Menu icons)... in both cases (LCD or CCD) this isn't a job that you could solve yourself; this wrong
include distorted
card. I
suggest check THIS LINK for additional details in this previous solutions for an Defective
CCD (Charge Coupled
Device) and next contact your Sony service. Istrongly suggest(taking intoconsiderationthe age of yourcamera) to
Hope this helps and just keep in mind that your feedback is important
and I'll appreciate your time and consideration if you leave some
testimonial comment about this answer.
include distorted
card. I
CCD (Charge Coupled
Device) and next contact your Samsung service. Istrongly suggest(taking intoconsiderationthe age of yourcamera) to
this answer.
If camera shows Menu item or any on-screen display in LCD but no live view to take picture then it can be either aperture problem or defective ccd imager. And if you do not see any display icon in LCD then of course LCD section is bad or LCD back light is Off for some reason. Try to see faint image in LCD if it is totally blank by pointing good amount of light with flash light or some thing.
Mine has the same problem. I have slapped the bottom of the camera on my open palm a couple of time while it was on and the picture came back on!
Hope yours is as easy of a fix!
I have a sony cybershot DSC-S650, the LCD was very dark and could not
see anything except if I pointed it at a bright object, everything else
worked ok. I could take pictures but could barely see them in playback
as well.
I took it to Sony authorised repair outlet and was told
the CCD was damaged, they charged me USD $55 to repair it (in Quito,
Ecuador)
CCD malfunction, common with Sony manufactured CCD chips. You are in luck, its a free repair regardless of warranty date. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=223&modelid=8044#
Camera does not turn on.
