Question about Lands Phones
Bought handset kxtgfa51b to add to my kxtge630 base and pressing handler located and putting the handset on its base I keep getting message main unit no power?
6ya staff
SOURCE:
CORDLESSGURU
Chris Barclay
  • 106 Answers
SOURCE: handset does not work
Your handset is no longer communicating with your base. Depending on your model, the solutions can be a couple of different options. If I could view pdf files on this computer I would look it up for you. But here is the link to the manual on Unidens website- http://www.uniden.com/pdf/TRU8865-2om.pdf
Nonetheless, give this a try. Power down your base, and pull the battery out of your handset. Plug the battery back in the handset and set the bad handset in the base cradle, and then power up the base. Wait about 30 seconds, then give the phone a try. If it still does not work, then you need to try to "re-register" the bad handset back to the base. Look in the manual under "registration" procedures. Hope my help fixes it for you. Good Luck, CG
Posted on Feb 18, 2008
Anonymous
SOURCE: GE 25931 Cordless Unavailable
I had the same problem recently due to a power outage during a storm. GE advised to disconnect the power cord and telephone cord on the "mother" unit. Wait five minutes. Then plug it back in.
I placed the "mother" phone back in the base. After the screen flashed on the "mother" phone, I removed it and then put the other two portables in the "mother" base.
This corrected my problem and all is now well.
Posted on Feb 22, 2008
Anonymous
  • 86 Answers
SOURCE: GE portable phone Model #25840
you have to tell the base which is the main hand set and which is the secondary in the base set up menu
Posted on Aug 17, 2008
Anonymous
  • 550 Answers
SOURCE: Vtech ia5870 dual handsets model problem:
http://www.vtechcanada.com/manuals/5870ciben.pdf
from the troubleshooting section of the manual
• Unplug the base unit’s electrical power and remove the battery from the handset. Wait for 15 seconds then plug in the battery place the handset in the base unit and plug in the power. Allow up to one minute for the cordless handset and base to synchronize
not a guarantee, something to try
Posted on Aug 30, 2008
Anonymous
SOURCE: how do I add an extension handset to my current config?
IF it was a used handset it was likely registered to another base. I just switched bases (1line to a 2 line base). I had to "deregister" the handsets from the old base. I am not sure if you can deregister if the old base is not present? With the old base plugged into power I hit the "function key" at the bottom left of the handset and scrolled down to initial settings. Under registration is "deregistration". I selected that and it put the handset back to its default out of the box. Then simply hit the mute button on the New base and OK on the handset. Worked for all 5 of my old handsets.
Hope this helps
Posted on Feb 23, 2009
Hi, I have a DECT2085-3 base with 3 handsets. I would like to add another handset. I bought two used handsets and would like to register them to my original base. I am having trouble with the selecti
In the instructions you need to find how you Sync the base and add that number phone to the base. All have different ways so try the company website on google.
Dec 09, 2014 | Uniden DECT2085-3 Trio Cordless Phone
Unable to change handset registrations from old base to new.
Hello Linda,
See if my FixYa Answer from this previous post helps to Deregister and Register your old handsets to your new base.:
My phone says no link to base but am right beside it
Regards,
-Ellsworth
Mar 25, 2017 | Panasonic KX TG4031 Cordless Phone
I bought some handsets but they were registered to another base. How do I deregister without the base
First, select Deregister HS from the main menu. Secondly, press the red phone button and the # key simultaneously for about 5 seconds to finish deregistration. You will then see a message telling you to place the phone in the cradle of the base unit to register it to your unit. An "operation complete" message will confirm that the handset is now registered and ready to use. Good luck.
Jan 16, 2011 | Uniden TCX905 Cordless Accessory Handset...
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
It said base no power
Remove then replace the batteries from the hand set. You should now get dial tojo.
Oct 25, 2010 | Panasonic KX-TGA101S Cordless Handset
Expandable handset will not register
It sounds like the base unit has other handsets registered to it. This is why you are getting the message "All Handsets Registered". You will need to reset the base unit in order to register your two handsets.
Hopefully this will help you. Put the phone in an easily accessible spot where you can plug it in and unplug it easily. Unplug the phone, wait a few seconds, and plug it in again. Now, unplug it again, and before you plug it in once more, hold down the Locator button as you plug it in and all lights should flash on. It should emit a long beep, which means it has reset. If not, you will need to unplug it once more and hold down the Locator button again as you plug it in.
Once it beeps, it should allow you to add your handsets. If there is nothing on the handset display, press the off button, menu, then 001. It should then read "Press LOCATOR on base for 3 sec, Then press ok". At this point, you will need to hold down the Locator button until it flashes before hitting okay. The handset will be registered when it reads "Handset 1 Registered".
If this doesn't work, I would call Panasonic.
Good Luck!
~Julia
Jun 04, 2009 | Panasonic KX-TG6071M Cordless Phone
Can put in base id
Did you try this (from the i5801 manual) -
To register a handset to the base, follow these steps:
Step 1: If ENTER BASE ID is displayed on the handset, proceed to the next step; if not, press MENU on the handset, then press ▼ until REGISTER is highlighted; now press OK.
Step 2: Locate the 15-digit Base ID number by pressing, at the base: MENU, then press until DISPLAY BASE-ID is highlighted, then press OK.
Step 3: Carefully enter this number using the handset dialpad. If you make a mistake, press to backspace. When finished, press OK.
In a few moments, the handset will be assigned a number (1-6). This will be the lowest available number in the sequence not previously assigned to another system handset.
Step 4: Repeat the procedure for any other unregistered system handsets.
Reply back if you have success. The Base ID is not from the bottom of the base unit, but is something you get by following Step 2 above.
Feb 04, 2009 | Vtech i5807 (735078006394) Cordless...
Got instruction to unregister KX-TG6074B
If this error message displays on your handset, please follow the instructions below to deregister your old handset before registering a new handset.
1) On the base unit:
Press: FUNCTION or PROGRAM
Button name varies by phone model.
2) Press: MUTE
3) Enter the numbers 3, 3, 5, #
4) Enter the handset number (1 to 8)
Mar 14, 2008 | Panasonic KX-TG2740 Cordless Phone
Phone issues.
1st) you must identify the ranking order of your handsets. Put all your handsets in the main base cradle and it will tell you which phone is your handset ie: (1) (2) (3) (4). (if you are reseting a handset, chose a number that is missing to reset your phone to) Now, with NO handsets in the main base cradle. Hold your phone and press "menu", then key in the numbers 00. Now, don't do anything with your handset. Go to the main base cradle. On the bottom, where it says "locator" press the "select" button until you get the desired phone rank needed. H1,H2,H3 etc... Then, press and hold the "call" button, under "intercom". (The charging light should start flashing) Now, go to your handset and press the "OK" button on the top upper right corner. At this point, your phone should be working!
If you are still having problems, call Panasonic Customer Service at 1-800-211-7262 for tech support. PS: your handset may show model KX-560B, but your main cradle base will show the actual phone model listed as KX-TG5633
Mar 14, 2008 | Panasonic KX-TG5633B Phone
Lost comunication
I solved this problem with a RESET of the handset. Instructions from the Philips website: Please perform a reset of your device. You will not loose your recorded data (phonebook and personal settings are being kept). 1. Unplug the mains of the base station. 2. Remove one of the batteries of each handset. 3. Put the batteries back in and re-plug the mains of the base station.
Mar 09, 2006 | Xact Communication XG2200 Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
