Computers & Internet Logo
Debra Coleman Posted on Aug 08, 2009
My computer won't boot. It just says something
My computer won't boot. It just says something like cannot read disc press CNTRL, ALT, Delete. If I press F8 several times it does a loud beep
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Aug 08, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
5480
Points
41
Sounds like your hard drive lost its boot sector. What version of windows is it running? you probably need to boot your os cd and run a repair...give me more details and I can help you more
Acer aspire laptop 7560-sb416. When turn on screen says disc read error press cntrl+alt+del to restart.
U might try to repair the system but with that message it seems there may be something wrong with your hard drive. Use a cd diagnostic disk to check out the drive to confirm.
1helpful
Hi there, hope you can help. Have an eeepc 701 on windows xp. Have a black screen with the message ' a disc error occurred press alt+cntrl+delete to restart.' These instructions don't work. ...
try these go to any cyber and download a bootable cd like hirrens boot cd, which can be able to log in and check if you can see your hdd(harddisk). if yes then repair your operating system.
if not
1) buy a new hdd and start a fresh then recover your data
or
2) take it to a near by technician or if the pc had a warranty for repairs but remember to recover your docs
1helpful
2answers
Need one manual for found the cmdos reset
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Also you might try click start run type cmd you are in DOS type exit you computer should reboot or press and hold all of these cntrl alt delete your computer should restart
hope this helps
Black screen bootmgr is missing cntrl alt delete to restart win xp hp pavilion 7955
  1. Boot your computer with the Windows XP CD.
  2. On the "Windows XP Professional Setup" menu, select "R" for Recovery Console.
  3. You will be prompted to select the Windows installation to repair, usually option 1.
  4. Enter the Administrator password, followed by enter.
  5. At the command-prompt, type "fixboot" (excluding the quotation marks) and press enter.
  6. Press Y and enter to confirm.
  7. Remove the XP CD when complete, and Restart the PC.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
My eee netbook 1005hab keeps sayin a disc read error occured it saids press alt, ctrl,delete but i press that and the same message pops up
TRY TAPPING F8 ON BOOT UP SEE IF U GET OPTION TO REPAIR MY COMPUTER OR DO U HAVE REPAIR DISC MADE IF NOT GO TO YOU TUBE LOOK FOR UR PROBLEM TO FIND RESTORE DISC ON THERE ,
Computer turns on and works fine once turned off the orange button comes one - then if I cntrl alt delete the system boots? what gives?
If you just hit the button, it's probably set to suspend. You should be using the shutdown procedure, or alt-F4.
My computer says disk read error press cntrl alt then nada
In most cases, all recent versions of Windows use Ctrl+Alt+Del to bring up the Tasm Manager. You can't usually use that key combo to restart your PC.
When you did that, was any application highlighted as 'not responding?' If so, that is where you should start looking for problems.
Otherwise, try to post additional information for us here.
-a.
2answers
Need password
ok best thing to do is to start the computer up in safe mode
when you boot up computer it will say press a key to go to "boot menu"
press that key
then select boot up in safe mode
then log on as admin and delete the password
if that dosnt work then you will need to download and butn this to dvd
http://www.hiren.info/pages/bootcd
make sure yu do not choose the ods version and you choose the gui if there are two versions
the gui has a graphical usser interface the dos is just like comand prompt
then go into bios set to boot from cd then choose the password tools and use it to delete it
good luck
My cisnet computer keep reading disk errors.i tying to install window xp. it also system window 32 problems. is a missing files. how do you fix it?
u need to format using a windows 98 sec boot disc. place the floppy in to the comp. switch on the comp. let the disc run, making sure your bios is set to boot floppy first. when disc is finished setting type fdisk then when finished delete drive by pressing 4 .add drive when finished by pressing 1 and following the insturctions. when finished press crtl+alt+del let the comp, reboot the when the disk as finished loading type format c: press yes let it run press crtl +alt+del again then take out floppy disc and put in winpx . as this sounds like you have a virus in your registery
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
