My Delta 473 is loose - I have looked under the sink and there is no brass nut - there is a brass u-shape plate that the water lines go through but no nut to tighten. I believe that I need to access some nut throught the faucet to tighten but I do not know how to open the faucet. Any suggestions on how to access the inside of the faucet from above the counter.
There should be a nut holding the plate on. What is holding the u-shaped plate up?? You can't tighten the faucet from above. Seems strange the nut disappeared.
Do not take faucet apart!! look underneath again there should be a large round brass nut with set screws in it that is the mounting nut loosen the set screw see if you can snug the nut and then tighten the set screw again
there should be a nut to tighten that plate up to the bottom of the counter. is there anything with threads penetraiting that plate?
There should be a nut holding the "u-shaped plate" up (if this is a single hole installation). Do you have a sprayer also? If so, the nut should be above where that connects. Please check again as the nut cannot fall off.
