Question about McCulloch Garden
Good Day, I have a McCulloch FG5700AK Generator that doesn't fire after the 1st pull. Got any ideas what the problem maybe?
I pulled the spark plug, put it back in the coil wire then groundedit to the engine. Pull the cord & got a weak orange spark, pulled the cord again - nothing. Let it set for awhile & tried it again, 1st pull spark, after that - nothing! someone told me to disconnect the oil sumption wire, where's that located? John Babor
6ya staff
SOURCE:
Anonymous
  • 1066 Answers
SOURCE: I just purchased a troy
remove the spark plug.  And pull the cord again.  if the carb float is stuck down or you overfilled the oil you could be hydro-locking the engine.  Check.
Posted on Mar 29, 2009
dmftrucker
daniel hendrickson
  • 1922 Answers
SOURCE: Unable to pull starter cord at all
pour some gas/oil mixture down sparkplug hole and let it soak and see if the rings are carbon blocked
Posted on Oct 07, 2009
philschneide
philschneide
  • 448 Answers
SOURCE: my mcculloch petrol hedgetrimmer wont start
The fact that your engine turns over easily with the spark plug removed simply means that, with the plug removed, there is no compression, so the piston goes up and down very easily.
If it has been a while since you ran the machine, and if you left gas in it, your carb may have gotten gummed up from the gas losing it viability and turning to something like varnish. You might try spraying carb cleaner into the carb (with the air filter removed), let it sit for a few minutes, then try starting. In the future, you probably should get some fuel stablizer (available at almost any hardware store) and add it to the fuel that you use for your small machines. It will keep the gas viable for a much longer period of time.
Hope that you are lucky enough that the carb cleaner, a good dose, will work. If not, you may have to disassemble and clean out your carb. (if you've never done that, a series of digital camera photos so you know where to put things back is a good idea).
Posted on Oct 18, 2009
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: Can't pull the starter cord,
Hi and welcome to FixYa, I am Kelly
Remove the muffler and clean out the exhaust port and screen. You will have to disassemble the muffler and clean off or replace the screen item 8 of this link:
http://www.partstree.com/parts/?lc=echo&mn=CS-330T++S%2FN%3A+C08611001001+-+C08611999999&dn=7946
Before taking the muffler apart... unhook the spark plug and just pull it though with the muffler removed. If it pulls normally you know you have found the problem.
If it still pulls hard...check the exhaust port of the cylinder head for 2 tiny holes (not screw holes) Some have them some don't depending upon the year of the saw. If you do find 2 small holes that appear clogged with carbon... do your best to clean them out.
Thanks for choosing FixYa,
Kelly
Posted on May 15, 2011
Testimonial: "TRIED SOULTION BUT THAT DIDN'T HELP."
Tony Masur
  • 10 Answers
SOURCE: troybilt 5500 generator pull cord locks up...just had it for one year...cord was very easy to pull @ first...but lately it locks up when I try to start it...any suggestions?
your cord is too long is why its binding up ,,,on the tee hand where you put your hand on to pull,,,,take a screw driver and push up the tied knot out and away from the tee handle,,,,take and make another knot about 8 inches and pull the cord back into the tee handle then try it again. Most have a long rope, cord etc for maximum pull,,sometimes they go overboard on the length and it binds up on the rewind of the recoil system
Posted on Dec 23, 2011
Testimonial: "Tony, Thank you for the help. You're right about the cord being long. It was a strain on my wrist to pull the length of the cord."
How can I replace carburetor?
I believe the electric solenoid is a fuel shut off. solenoid needs energized, normally with switch 12 Volts. other then float bowls are the carbs. identical, if they are switch bowls, should work. If not you will have to add switched power to solenoid, the link below looked similar to yours.
Generac Generator Carb removal and disassembly
McCulloch Generator Model FG5700AK
Jan 25, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
Have a mcculloch fg5700ak portable generator. 7 yes old. Used 1 time for 20 hours. Sitting up since. Gas was drained so carburetor fine. Turn everything on and pull cord and it just won't kick on over and...
Make sure fuel tap is turned on. Tap the bottom of the carburettor with a wrench to make sure the float isn't stuck. Is the ignition on/off switch in the on position? make sure the oil level is ok as these usually have a low oil cutout which stops the motor when oil gets low. All that being ok give it full choke and it should start. Remove the sparkplug and check there is spark across the electrodes. (earth the thread part of plug on motor) If no spark replace the sparkplug.
Oct 03, 2014 | Electrical Supplies
Generator will crank but will not start
First check spark while cranking over( pull the plug wire hold by insulator about a 1/4 inch away from any ground, you should see a strong spark. then check to be sure the fuel is pumping from yhe carb., if no fuel try a short squirt into the carb intake. should fire up if you had spark.Its generally a good idea to put in a new plug and be sure to check the gap.
Oct 01, 2013 | McCulloch 11 HP 5700 WATT GENERATOR
Generator not making electric
You have a faulty inverter board on the unit. I would warranty the generator in this case, or have the manufacturer send you out a replacement board to swap yourself.
Aug 27, 2013 | McCulloch Fg5700ak 5,700 Watt Portable...
My 5700 watt 11 HP McCullough generator wont start. I'm getting good gas to the plug but no spark.
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
Oct 25, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
Have an fg5700ak runs ok but no power output what
Typical diodes are 10 amp for these. The stator and rotor both have VERY low resistance readings. The reading typically will be below that which will register MEANINGFULLY on the digital meters.
My generator had 10 amp diodes with surge protectors across them. One of the protectors shorted and generator output was zero. Mine is a 6KW diesel silent unit.
Replaced the diodes with 70 amp ones with surge protectors that have 20 times the energy absorbtion as the originals. Unfortunately this required some lathe work to make holders for the diodes and the surge protectors to ride on the rotor.
Used the light bulb trick to remagnitize it once diodes were replaced.
Nov 10, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
Garden Logo
37 people viewed this question
Top McCulloch Garden Experts
roeb
John Trevino
Sheldon Dedek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
