Frigidaire FEF366 Electric Kitchen Range Logo
Posted on Aug 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Glasstop heating coil replacement
One of our heating coils is not working. How do determine what to replace? I can not even open the top.
Anonymous
Level 3:
President:
  • Master 2,559 Answers
  • Posted on Aug 08, 2009
Anonymous
Master
Level 3:
President:
Answers
2559
Questions
Helped
1213515
Points
9283
To remove the top,open the oven door and the screws for the top are located on the top of the door opening,remove the screws and the top will open,then you will see 2 screws that hold each element in place,just remove the one not working.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 12, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
424
Points
Where are the temesates for the burners located?
Flame on dryer goes on off
see this causes and use the common sense.God bless you
If your dryer doesn't heat, check these: Igniter Gas valve coils Thermal fuse Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. To determine if the igniter is burned out, watch the part testing video at the bottom of this page. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
I have a 7yo Kenmore Elite gas dryer w/no heat. I tested all the possible culprits with my ohmmeter. I found the ignitor was not glowing so I replaced it. Now it glows but I still have no heat
The glowing if the ignitor indicates that the circuitry is good but the flame/radiant sensor is bad and/or one or both of the gas valve solenoid coils are not working. The flame/radiant sensor bypasses one the solenoid coils then when power is applied to the ignition circuit, the first coil opens the first valve, the ignitor glows and the flame/radiant sensor gets heated. It's contacts then opens when heated enough to unbypass the second coil and allow the gas to flow and be ignited.
Make sure the flame/radiant sensor is properly in place and aligned with the ignitor to allow proper heat sensing. You may check the continuity between the sensor's contact terminals as the ignitor glows. At first, the terminals should read close (zero resistance) and then open (infinite resistance) after about 30 seconds or so. If this is not the case, the sensor is not working and must be replaced.
The solenoid coils, one with 2 prongs and the other has 3, sitting on top of the gas valves must be both replaced if the flame/radiant sensor turns out good. But before doing so, make sure to run a test with the dryer completely assembled because sometimes the gas do not ignite when the dryer's cabinet is open. This is to prevent unnecessary replacement of the coils.
Feel free to update us about the result and if you need further advice.
2helpful
2answers
Dryer not heating up
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks.
If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the
wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed
component. The switch is inside the dryer main housing near the door frame.
Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Check for continuity you should have none with door open, and should have a reading when closed.
If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause
heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the
thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape
or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged
with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's
plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
My gas dryer is 3 years old and it starts to heat up when it is turned on and then stops heating while running.
This is usually due to the two gas valve solenoid coils sitting on top of the gas valves, one with 3 prongs and the other has 2. The coils work fine when cool but one or both are weak and fail when get heated. Both coils must work to open the two gas valves in order for the dryer to fire up. The coils are not repairable and the only viable solution is replacing both of them. Replace the solenoid coils and it should solve the problem.
I have a Maytag Glasstop stove (Mer5875qas). THe left front dual burner only heats on the outside ring. The inner portion does not heat. Could it be a wiring problem or is it more likely that the burner...
There are 2 likely causes. It is more likely that the element is open circuited and needs replacing. The hotplate controller could also be faulty. The circuit needs to be tested to determine the faulty part.
Dryer comes on but will not dry. I have determined that the lint screen and vent hose is clear. Any ideas ???
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
For video and pictures on how to replace the element go to the following website:
Our gas dryer takes a long time to begin heating then it stops heating midway through the cycle. The drum continues to turn. We have had a slight smell of gas.
It sounds like the safty coils on top of the gas valve are not working properly. As the dryer heats up the coils expand creating an open curcuit in the coil. There is a repair kit to replace the coils. This should be done by a licenced gas fitter.
Dec 29, 2009 • Dryers
1helpful
Maytag neptune model mdg3000aww heats for 20 - 30 second then the burner stops.
The most common failure item is the gas valve coil(s)
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below are some links provided by, www.repairclinic.com. This can assist you with diagnosis, parts ordering and replacement.
Dryer parts breakdown link:
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
Coil illustration link:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg3000aww-%3d%3di686303&PartID=686303
Igniter
Gas valve coils
3helpful
2answers
Maytag Neptune MDG5500AWW Not Heating
The coils are the #1 failure in gas dryers, below is a description of how they work. This excerpt from; www.repairclinic.com.
9helpful
Maytag neptune (gas dryer) just stopped heating up...was working fine yesterday. The dryer is 8 years old...never a problem. Does the heating elements need replacement?
Gas dryers utilize a gas valve, ignitor assembly, and a series of coils mounted on the gas valve to provide heat and safety. The gas valve coils are the usual suspect when it comes to a "No Heat" complaint. I have provided a checklist from www.repairclinic.com, for your convenience. They also provide disassembnly diagrams and repair parts.
Firstly, ascertain that you have made an adequate "Heat" selection, then read on:
Igniter
Gas valve coils
Thermal fuse
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
