If the external hard drive was unplugged during a file transfer or without using the Windows "Safely Remove Hardware" utility, there might have been data loss.
If you have a second machine, try plugging the drive into it and see if you can read the drive.
Also, try transferring a file onto the drive, unplug the drive, plug it back in and see if the file is still there. If it's not there, it could point to a problem with the cable. Try to use a different USB cable and perform the same test.
If none of those suggestions work, the drive could have gone bad. It's not uncommon for hard drives to become unreadable due to bad sectors, or mechanical failure. You may need to purchase a new drive.
