Sarkari Result is providing the results of government Exams and admit card of the government exams. We provide the updates of the government exam results and admit cards. We provide the Updates of the government exams. We provide the admit card of the government exams and you can also know your result from this website.
SOURCE: sound problem on Sony TA-343 amplifier
If you're not experienced with troubleshooting and repairing electronics, I strongly suggest professional service. There are internal problems and most likely several components will need replacement.
SOURCE: need to find wiring diagram for a sony TA-AX 295 home amplifyer/eq
Hi *****, Try these URL's good Luck. YUBEUT http://www.eserviceinfo.com/ www.hisierrahifi.com
SOURCE: Nakamichi TA-4A receiver no sound
HAI,AMP WORKS FINE , CONNACT ANY OTHER TO AMP(CD,DVD,COMPUTER,MOBILE,TV) IN BACKSIDE INAUDIO OR PRE_AMP .THEN SELECT PLAYER TO IN MODE YOU HAVE INSAERTED.THE SOUND IS OK
SOURCE: RCA Sub-Woofer
Did you try making sure the subwoofer is turned on under the set up menu on the Sony Receiver?
Press Set Up, Press the left or right button above the scroll wheel until you get to SW. It should say SW: ON or SW: OFF. If it says SW: OFF, use the Scroll wheel to scroll right until it says SW: ON. Also, make sure you aren't in 2CH mode, try A.F.D or surround sound.
SOURCE: No sound on Sony TA-AV501 Receiver
Could be a solder connection. Check the speaker select switch and that tape monitor is off. You can take it to any Radio Shack they will send it to service $69.00 labor plus parts for receivers. $20 deposit for the estimate that comes off the repair bill if you get it fixed.
