Lands Phones Logo
Sherree Sanders Posted on Jun 17, 2019
My phone says land line in use.. cant find the lost handset
T Tatro
Level 1:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 20 Answers
  • Posted on Jun 19, 2019
T Tatro
Contributor
Level 1:
Greenhorn:
Cheetah:
Answers
20
Questions
0
Helped
4566
Points
38
Unplug all phones from all jacks, including fax lines and computers and SAT Tv. Find one phone that you know works and plug it into one jack at a time.
Land line in use could indicate a trouble on the actual telephone line. and you may need to call Telco
4 Related Answers
Anonymous
  • Posted on Jan 05, 2009
SOURCE: ELBT595 & TCX905 compatibility
from uniden regarding your base station:
"This expandable base system is compatible with Uniden handset models ELX500, TCX400, TCX440, and TCX805. However, only the ELX500 is compatible the base system's Bluetooth and CellLink features."
corona63976
Sam Corona
  • 6 Answers
  • Posted on Nov 23, 2009
SOURCE: After working properly for a long time, suddenly
i would have to say its your antenna from where they charge.i dont think its sending a signal.try replacing that or the whole unit might need to be replaced.
Anonymous
  • 81 Answers
  • Posted on May 04, 2011
SOURCE: when I plug in my
There is a short on your base station throw it out and buy a new one.
Bill Boyd
  • 53816 Answers
  • Posted on Apr 27, 2018
SOURCE: I have a Panasonic land line phone with 3 handsets....one of handsets has the mute sign on the face. I can still dial the phone and talk on it, but it does not ring. What do I
unclick the mute
3answers
My phone says line in use
Line in use means the line is seized or off hook, this can also be caused by a short on the phone line.
How do I install my Panasonic KXTGA401 phone?
The KX-TGA401 is a handset for specific Panasonic cordless telephone systems. Connecting the handset requires registering (pairing) it with the base and if the base can support another handset. First make sure that the base is plugged into an active phone line (land line) and that the power adapter is plugged in and working properly. Charge the handset before attempting the registration process.
Then make sure that the phone system is in standby (no calls). Press and hold the Locator button on the base for about 5 seconds (wait until the tone sounds). If all of the handsets that are already registered ring, press and release the Locator button and then press and hold it again. Once you hear the registration tone (some models), place the new handset in the charger on the base. Wait for the long beep and the registered symbol to appear.
If the not registered symbol appears, try registering by using the handset menu. Press Menu # 1 3 0 (the key below 9 and individual number keys) on the handset. Press and hold the locator button until you hear the registration tone as above. Then press Select and Save on the handset within 90 seconds of hearing the registration tone. Wait for the handset and base to complete the registration process. You'll hear a long beep.
The first registration method is given in the manual for the handset, http://help.panasonic.ca/viewing/ALL/KX-TGA401/OI/TGA401_PNQX2390ZA/TGA401_PNQX2390ZA.pdf. The second is from the page 31 of the manual for the KX-TG653x (KX-TG6531 base) system, ftp://ftp.panasonic.com/telephone/om/kx-tg6511_mul_om.pdf . The KX-TGA401 handset works with other bases as well. You may want to check the manual for your phone system in case there are differences. Other compatible phone systems are the KX-TG401x, KX-TG403x, and KX-TG651x.
I hope this helps.
(I make sure that the land line is active by checking for dial tone with an old corded phone.)
What does Out of Range or No Power at Base mean?
Hello, Gwen -
If you are asking about a cordless land line phone. . .
"Out of Range" means the handset has lost its connection with the base station. Cordless phones are actually forms of radios. They need to be in radio wave connection with the phone base.
"No Power at Base" means that the electric power cord for the phone base is not plugged in or loose in the electrical outlet or that the batteries in the cordless handset need replacing.
Read information here:
http://bt.custhelp.com/app/answers/detail/a_id/10835/~/why-does-my-cordless-phone-keep-showing-searching%2C-base-or-range-out%3F
I suddenly have no Caller ID name, number and announcement. I have tried the manual that came with the phone. model KX-TG7624SK 6.0 Bluetooth Talking Caller ID Panasonic. I am tired of answering "cour
Ann also check with your telephone line provider for the land line calls that the subscribed service has been activated that forwards the calling line identity to your land phone line. Could be it somehow has become lost accidentally by the phone company.
It would be worth them checking it has not fallen off your subscriber settings to eliminate it as a possible cause)
Talking Caller ID Handset Dial #162 1 on 0 is off
Base Unit caller id Dial #*162 1 on 0 is off
Guess this toggles it from 1 or 0 in the settings
My land lines are working but all my handsets say check tel line...no dial tone or response. Batteries are good according to tester. Anything I can do??
ck the red and green wire that goes to the system those 2 make the phones work just do the main main phone first , , it does not sound like the phones are broke you are not getting a dial tone due to no connection to the line itself
Rogers problems
This has become a growing problem:
  • As land lines have been reclaimed or replaced in the phone company networks;
  • As the growing older population has lost hearing sensitivity.
  • Because secondary carriers don't always receive the best or least crowded connectons (especially in case of residential versus business which pay more for service).
If you are getting static and cross talk (hearing radio or other people's converstations) notify the phone company and you will probably provided a new connection.
IF the problem is persistent without such interference, consider an amplified phone--some states (California for instance under Federal auspices) makes such equipment available free to hearing impaired. Also check the quality of your household wiring and connections.
Check with you neighbors--if they don't have the same problems, complain to the phone company. If they do, complain together.
Finally, some phones are simply too poor in quality to provide good sound. You might want to upgrade: either the phone set or its line or handset cord.
Panasonic phone says check tel line
Check cable conections from phone box on wall to base unit, make sure that the conectors are fully inserted. If possible plug a different phone into box to make sure that line is working. Hope this helps
9helpful
5answers
I have a Tesco Cordless DECT phone model ARC201. Both handsets have come up with range out. I have switched off the phones, unplugged from wall etc. and then reconnected - and they remain the same. I've...
Maybe a little bit late, this is the solution for registering the handsets: hold the button on the base until it starts beeping, then, on the handset, go to the Register menu, select base number - in my case it's 2, then it will ask the PIN - the default is 0000, and that's it.
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
