Laser MP4-V970 MP3 Player Logo
Posted on Aug 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LaserMP4-Q12 Personal Media player. Cannot get music files to pl
Thisunit is a nightmare. I use Windows media player to Sync music to it and when I do it comes up with "Format Error" and will not play.
The disc that came with it has a driver marked for Windows 98 and I have XP home edition. Why is it that I cannot find a website with the appropriate driver. And why does it not want to work. The instructions do not tell you how to convert and load videos or music. do they have to be in MP4 format and if so HOW??????
IT Solution
Level 3:
  • Master 805 Answers
  • Posted on Aug 08, 2009
IT Solution
Master
Level 3:
Answers
805
Questions
Helped
156570
Points
2358
Ya u have many option to solve this problem. first is that ur music format not supported ur player so it show this message. 2nd u can download ur driver from internet. 4 this u can try in google just type this what do u want. then u will get. 3rd is there are many software for convert mp4. 4 example u can use total video converter, im too mp4 converter. thanks
4helpful
4answers
How do you add songs on device
Hi atiug b...
Downloading Music to MP3 Player
1...You must download and install Windows Media Player 11 on your computer.
NOTE...Some older MP3 players will not work with Windows Media Player 11 or Windows 7 with Windows Media Player 11.
If this happens to you, then you will have to uninstall Windows Media Player 11 and install Windows Media Player 10.
2...After you have downloaded and installed Media Player on your computer.
3...Open Media Player on your computer.
4...Install all your music into Media Player that you want to install on your MP3 player.
5...Plug in your MP3 player to the computer using your Data/Sync cord, be sure that Windows Media Player is on.
6...Media player should recognize the MP3 player and sync with it.
7...After it is sync'ed with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player.
Free Answer...Please take time to rate me
How do i transfer music from my sansa clip to my computer
Syncing and transferring music files to the Sansa player using Windows Media Player 10 How do I sync or transfer music files to/from my Sansa player using Windows Media Player?
STEP 1 - Connect the Sansa player to the computer
STEP 2 - Run Windows Media Player
1. Go to Start > Programs > Windows Media Player.
NOTE: If you can not see Windows Media Player on the menu, go to Start > Run then type WMPLAYER then OK.
STEP 3 - Sync files to the Sansa player.
1. Click the Library tab.
2. Drag the music files to be transferred on to the right panel.
NOTE: You can also right-click on the title of the song and select Add to sync list.
3. After creating the list, click the Start sync button to sync and transfer music files to your device.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
How can you listen to music
First, you will have to transfer the music to the mp3 player. You can transfer music and pictures to your player using Windows Media Player. YOu can download it from here:
http://windows.microsoft.com/en-US/windows/products/windows-media-player
Once you have installed WMP, reboot and plug your mp3 player. By default, Windows Media Player automatically loads all the music and picture files stored in your My Music and My Pictures folders into the library. If you add new files to these folders, they will also be automatically added to the library. Then you will have to synchronize your mp3s player with WMP.
You can sync your music and pictures to your player using Windows Media Player. Simply connect your player to your computer using the supplied USB cable, set up sync, and you will be ready to sync your media library to the player. When you connect your player to the computer for the first time, Windows Media Player automatically selects the sync method (automatic or manual) that works best for your player. Automatic: If your player has sufficient storage space (at least 4GB of free space) and your entire media library can fit on your player, your entire media library will be automatically copied to your player as soon as you connect it to your computer. Manual: If your entire media library cannot fit on the player, then you will be prompted to manually select specific files or playlists that you want to transfer to your player.
Once you have transfer the music you want-unplug the player from the computer and that's it. If you have more doubts, you can download the manual from here:
http://download.p4c.philips.com/files/s/sa6045_37/sa6045_37_dfu_aen.pdf
2answers
Screen says I have to synchronize to continue subscription how do i synchronzie my mp3
Windows Media Player 10:
Windows Media Player 11:
1. Click the Sync tab.
2. Drag files to be synced on to the right panel, under Sync list.
3. Once the list is complete, click the Start sync button.
For further reference, go to:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=389&p_created=1225223428&p_sid=YNkfm7tj&p_brand=sansa&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0yMTUsMjE1JnBfcHJvZHM9NCZwX2NhdHM9JnBfcHY9MS40JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTI*&p_li=&p_topview=1
Unable to load music on to mp3 player
You can use Windows Media Player to transfer songs to the player without using Rhapsody. You will need to sign up for an online music service that is compatible with the player (in other words - not iTunes), or have songs on CD.
Here are some helpful links on using Windows Media Player:
The instructions in these pages, which are largely links, pertain to Windows Media Player 10 and 11 only.
Windows Media Player is made by Microsoft. The general help page for Windows Media Player is:
http://www.microsoft.com/windows/windowsmedia/default.mspx
Through this link, you can enter a variety of search terms that will help you find what you are looking for (exs.: “add files to my mp3 player”; “delete files from my mp3 player,” etc.)
Important Vocabulary:
The code word for “mp3 player” in Windows Media Player is “DEVICE” or “portable device”
The code word for adding files is “SYNC,” “syncing,” or “synchronizing”
The code word for copying files from CD is “RIP,” or “ripping”
The code word for files stored on both My Computer and my Mp3 player (when it is connected to the computer) is “LIBRARY”
To add files (SYNC) to your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/wmp10/harrison_wmp10.mspx
To add files (SYNC) to your mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/player/faq/sync.mspx
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
To copy (RIP) files from CD to Mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/getstarted/ripcd.mspx
To copy (RIP) files from CD to Mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/easystart/mp11guide.aspx#RippingCopySsongsfromCDstoYyourCcomputer
2helpful
I don't know how to download music from saved files on my computer.
You have to use Windows Media Player to Sync music files from your computer to the Coby mp3 player.
My Directions:
3helpful
2answers
My Phillips Go Gear 8GB MP3 player wont sync music
Windows Media Player 11 ruins this player. Uninstall Windows Media Player 11, and roll back to Windows Media Player 10. Then use version 10 to sync songs to your device.
I downloaded some music on my mp3 player and now I want to erase it but I can't seem to access the hidden file TCNANDO.
Don't erase any files other than music files - don't erase system, dat, hidden, or ini files - you will destroy your mp3 player.
Use Windows Media Player to delete music off your player:
My Directions:
Can't get music OFF my Craig.
My Directions:
2answers
Downloading music to mp3 player
My Directions:
Top Laser Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Laser Audio Player and Recorder Expert? Answer questions, earn points and help others
