Hello Joanne, the Sony CDP-C225, is a 5 CD audio player
To listen to your Sony CDP-C225, on your Toshiba 46sl412u, you have to connect the LR audio output of the Sony to the LR ColorStream® HD / VIDEO audio input on the back panel of the Toshiba, then turn on the equipment, charge the CD on the Sony and you put in the Toshiba the Video input and there you can listen to the music of your Sony
I send you the links to download the manuals of Sony and Toshiba
I hope you can interconnect the equipment and enjoy the music
Greetings Franco Dosil
Hola Joanne, el Sony CDP-C225, es un reproductor de 5 CD de audio
Para escuchar tu Sony CDP-C225, en tu Toshiba 46sl412u, tienes que conectar la salida de audio L R del Sony a la entrada de audio L R ColorStream® HD/VIDEO en el panel posterior del Toshiba, luego prendes los equipos, cargas los CD en el Sony y pones en el Toshiba la entrada de V?deo y ah? puedes escuchar la m?sica de tu Sony
Te env?o los links para que descargues los manuales del Sony y del Toshiba
Espero que puedas interconectar los equipos y disfrutar de la m?sica
Saludos Franco Dosil
https://support.toshiba.com/support/modelHome?freeText=2941924
https://data2.manualslib.com/pdf2/25/2419/241856-sony/cdpc225.pdf?aca4bda68ee4e97a5d512bb41ffa4c33&take=binary
SOURCE: Sony CDP-C225 will not read or play cd's
Try running a "Laser Lens Cleaner" thru it, preferrably one that uses fluid. You can purchase one at just about any retail store for 15-20. Good to have and great preventative maintanance. If that does not work, you need a new transport, they do not repair or align lasers. Too expensive. The replacement is 100-150 with labor and a new one is under 200. My suggestion would be if the cleaner does not work replace it and keep the new one clean. CD/DVD/PC etc. all can and should be cleaned 3 or 4 times a year. Best preventative maintanance you can do. Hope this helps
SOURCE: Would like to find replacement cables for old Sony
The cables you requirea re not special in any way, they are just standard dual RCA cables. I assume that you are trying to connect hte output of hte CD player to either the CD or AUX input of the receiver, yes?
If not, please further describe what you are looking for. Neither service manual is available electronically, only on paper.
Thanks,
Dan
SOURCE: My tv is a toshiba 46sl412u with whites horizontal lines, how i can fix it?
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site.
