Hello Brian,
There is no reboot button on this unit. To reboot the receiver, simply unplug AC power for 30 minutes, then while plugging back in press and hold the power button for 5-10 seconds at the same time to reset.
Check all the speaker wiring for shorts, make sure they're also not touching the chassis of the receiver, or are not otherwise pinched or frayed. If all looks well, try disconnecting all the speakers and cycle the power off, then on again.
Try connecting the speakers one at a time until one of them shuts the Audio down. Check this speaker with a multi-meter and make sure it is reading between 4-8 ohms.
If not, the speaker may be blown and is causing the receiver to short out and therefore power the audio down.
If you still cannot get any audio through the system, then it likely has bad output transistors, or capacitor and is in need of service.
Here is a link to the Operating Manual
Good Luck,
JP
https://www.manualslib.com/manual/286996/Kenwood-107vr.html
SOURCE: my kenwood 107VR keeps turning off on its own,
If you are sure your speakers are good. This unit has a protect circuit keeping the unit from turning on. This recevier uses an ic instead of output transistors. A ic incorperates transistors,resistors,capactors in one assembly for size and costs. There is a number right on the front of the ic ,you can go on-line to buy the ic is is fairly easy to put in as long as you can desolder and solder in.
SOURCE: My Kenwood 107vr turns off
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on. Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up. You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it. If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good. If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Many Kenwood radios are configured with the same security codes:
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
Finding the Kenwood Security Code
There are backdoor codes for each Kenwood car stereo, based upon the model and the serial numbers.
These backdoor codes are closely held secrets. Outfits like Car Audio Accessories UK will sell you the code for your radio for £20.
Sending your RadioBack to Kenwood
If all else fails, you can send your stereo back to Kenwood to have the security code reset.
