I already checked the audio settings in my TV to make sure the TV Speakers are set to on and is not muted. Replaced the mainboard and the speakers once already, no change. Tried Youtube and Netflix on both mainboards, no sound at all. I'm wondering why I can't get any sound at all, could I have defective speakers?
The audio half is picked up on a separate board I think other than the main board as you say. Good luck
SOURCE: No Sound on RCA L46WD22
I own the L46WD22 for a few months and lost the sound and analog inputs, only HDMI worked, apparently this is a design flaw and they should have recalled all units. I didn't really needed the speakers because I have a sony receiver where I playback the sounds, but I decided to repair it myself after I neglected to take it out to the repair center and use the warranty. If you have a little soldering experience you can fix it, or you can buy the fuse and take it to any repair center, the problem is a surface mounted fuse that is located in the PCBA where all the signal inputs are, the component location is 1C33 the fuse has the letter F printed on it, you can't miss it, it's about 2 inches behind the tuner where you plug the coaxial cable. the fuse I bought it's marked with a G letter, it's 750mA, I just soldered it on top of the one it has, now I can hear the speaker and use the analog inputs (and now I'm the hero and have a very happy wife). the whole fix took me about two hours
SOURCE: No sound from internal speakers on HP Compaq 6710b
http://welcome.hp.com/country/us/en/support.html
THERE YOU WILL FIND ALL YOUR DRIVER'S
SOURCE: XBox 360 to Reciever to TV via HDMI no sound
I recently got the same receiver and had the same problem. Here's what I was told - and it worked for me:
Even though HDMI cables carry audio and video, for whatever reason this reciever won't accept audio through hdmi. Apparently only much more expensive recievers carry audio through hdmi. What you have to do is run optical audio cables from your xbox, cable box, dvd player or other video device to the optical inputs on the back of the reciver. Then you customize the scene buttons to match your video and audio inputs.
You can get these optical cables pretty cheap on line or even at target. Don't get ripped off by Best Buy for these cables. I love best buy, but they rip off on cables!
This receiver is great - once I got it all figured out and running right I've loved it! Hope everything works out for you!
SOURCE: My Netbook NC10--no sound comes out when playing
Go to the device manager and right click on the device and select update drivers. You may need to reinstall the sound drivers.
SOURCE: No sound on my Samsung 2333 LCD TV
use the menu setup and tell it how u want it to be configured and make sure tv speakers are on if u are using the tv, if not use the computer settings on the menu, u probaly already have found this out, by looking fully at the onscreen menu.
