SOURCE: I just went to start up my older model McLane gas
i would check the thread where your plug screws in it can be fixed with what they call a helicoil thread repair kit hope this helps.
SOURCE: I need another throttle lever for this craftsman
take top cover off look inside for a sticker or plate
SOURCE: can not start garden edger made by mclane
O-kay engine and motor are the same. I'll have to do some checking on this one and I'll get back to you.
SOURCE: I'm changing the cutterhead bearings
Was it packed with grease when you took it apart??? If there are gears there lubricate yes! Good Luck..
SOURCE: Where can you find the briggs and stratton model #
Hi Brian
Take the carb to your local small engine shop and tell them that you have the Briggs 3.5 hp engine with this carb...he can fix you up with a carb rebuild kit
Bud
