SOURCE: 2007 Toyota Sequoia Dashboard Access to Radio console FM Antenna
Pull off the 3 knobs for the heat controls. You will see a screw under the center knob. Remove it. Look to see if there are any screws near the vent grilles, remove them, if they are there. The whole center fascia then pulls out towards you. Remove the 4 bolts, and the radio is out. Easy.
SOURCE: Sangean PR-D3L AM-FM Radio RF gain intermittantly dropping. Would like circiut Diagram
The most common cause is a dirty rf controller, buy some electronic contact cleaner and take the unit apart and spray the compound into the pod and rotate control back and forth, repeat two or three times for maxium benifit.
